- Thayer
- KS
Will have factory solid wall on opposite end. Pictured end will have a 36" walk thru door and 14' x 14' garage door.Doors on both ends ? Looking really nice.
Yes, top tip of exhaust stack is 11'-3"gonna be able to get the Volvo in there...
I have a 30 X 48 and built my own baseplate. I am placing it in the keyway with grout to go over the top. I had the baseplate V-braked and then powdercoat painted. I felt the 7K they wanted for the baseplate was too much. I made mine for $1600. I will let you know if it works well. Did your cradle for the top arch suspension work?Good choice on the base plate mounting. I did the trough method. Forming for the trough was more time consuming (and materials) and then when the building was up, I had to fill in the trough on both sides of the building and then use angel brackets to the foundation bolts. If I had to do it again, I'd buy the base plates. US Steel does make an insulation kit that I wish I had bought. Once the building gets full of stuff, it's not so easy to go back and insulate it. Great deal on that scaffolding.
Yes, fairly well, there is a video link of an arch lift in one of the previous pages.Did your cradle for the top arch suspension work?
I will do the same then. The stabilization is going to be key to preventing a wreck. I may be happy in 10 years but this is so much work right now. Cement, sand and gravel was 15k . I have equipment and a laser to level it. Form boards were $1300. If a person is considering a Quonset I am guessing 20 % is the building and 80% is the rest if you do it yourself.Yes, fairly well, there is a video link of an arch lift in one of the previous pages.
