- Redmond
- OR
your right shaft is twisted because when your diff is unlocked power naturally goes to the right side.
You'll be happy with the 60. There are tons in scrap yards and even more aftermarket support.
It was actually the left shaft that I had to replace- the shorter (by 2"). The right shaft looked fine. The twisted shaft was also the one that was a bit bent, I'm wondering if that axle missed heat treating or something.
I might have thought through how it got twisted. We live in a small town with the highway going through the middle. When there's a lot of traffic, crossing the highway becomes an exercise in bravery, stupidity, or both. Right turns are no problem- but a left turn often requires precise timing and some fast acceleration. I know many times on left turns I'll punch it, leading to a significant "chirp" from the left rear tire. Slip then sudden grip. I'll bet that's how it happened.
Doesn't matter...I'm moving on to bigger and beefier anyways.
, and I am a big leaf spring supporter, but I think you have too much power, which is a good problem to have
