Also. What would everyone think of a 3 panel slider inside of the current 4 panels?
I've found the 4 panels to be a bit cumbersome for the following reasons:
1. you have to push the glass to either side behind the headrests on the seats, and once you lean back on the seats the cabin is so small there is usually pressure on the sliding windows that you have to lean forward to move the window or close it.
2. 4 panel sliders always have a bar right in the center that is highly visible in the rear view mirror. As small as the cab is, that bar in the center of your rear view mirror is fairly prominent.
3. trying to latch the latch and actually lock the 4 panel is a coordination challenge. You have to pull both sides in to the center then fumble with that latch/lock. 3 panel pull to one side and it automatically locks as you slide it over into place. (most models)
4. in a certain sense, 3 panels seem to be a little bit more secure - granted if someone wants in a jeep to steal something, they are going to get into the jeep regardless.
my manufacturer for the sliders does not currently make a 3 panel for the CJ8's but I have approached them about ordering a special run of 4 panels. But, it you have to have a minimum manufacturers run of them.
