rhino liner/line-x
scrambled eggs
chapin
sc
would like to spray the interior w/ bedliner...any preferences/suggestions? also, question i have would be whether or not i should spray the outer-lip (where hard top/soft top would sit)...reason for spraying= protection for ppl climbing in and out as they put their foot on body... reason for not= will create a problem w/ fitting of hardtop? another question: spray the bulkhead on both sides as well?
thanks
I won't get into the line/not line debate. I lined mine using a do-it-yourself product (herculiner- it's so rough it'll remove skin, but I'm happy with the longevity.)
I have seen Rhino and LineX- I much prefer the Linex, it looks almost like wrinkle finish paint. Just a LOT thicker. The Rhino I've seen hasn't been a consistent surface texture, and has had a rougher surface. You could have them do the to rail thinner, I'd guess over 1/8" would cause problems. Bulkhead is an aesthetic choice- I'd say do both sides, but be careful about the mounting surfaces. You would almost want is sprayed with the bulkhead in place, and then have them "cut" the seams before it sets up.
I am in the process of removing all the bed liner from my 8. I hate this stuff. Hides rust areas and is a cover up for rust buckets. If I could find the PO that had this done, I would like to shove all that I have removed in him where the sun doesn't shine.
Linex. I plan on getting mine done. eventually...
Line-x :thumbsup:
I just had mine done last week. I will post some pics this weekend. I was happy the way it turned out
People up here prefer Line-X, but we don't have a dealer in state anymore, so the only trucks that have it come up from the Lower 48.
I did Herculiner in my YJ tub that I put onto the CJ-7 (that eventually became my 8). (Since it was a galvanized YJ tub, I wasn't worried about "hiding" rust.) I really liked the Herculiner; in fact I liked it enough that I coated my center console with it, and undercoated my 8's rock-rails and front fenders. I did have it rub through in a couple place, but the first was because I had hauled a Dana 44 housing 700 miles, and the other place was where my speakers were constantly bouncing around on a corner of the rear fenderwells. I also did it over the rails down to the edge of the vertical panel and had zero regrets; I didn't find it interfered with either my hard top of my BesTop Supertop. The other advantage for Herculiner/DIY is that you can touch it up! It does, however, feel like sandpaper against your skin, unless you don't stir the rubber bits into the mixture. I intentionally avoided the rubber bits when I coated my center console and it came out smooth (but I wasted half the can that had the rubber bits). The most important thing for Herculiner is the prep! You must be anal with prep for it to adhere properly.
For my 8, I wanted a professional job, and ended up with Rhino. (Since my 8 isn't really an 8, and it has an aluminum tub, I didn't feel bad about it.) They have a couple different products now, and I went with the softer one. It doesn't have a painful texture at all. I had them spray both the inside and bottom, and specified places where I wanted it a little thicker. I'm happy with how it turned out.
I prefer Line-X as well... it just looks better. :) Though I may try Raptor DIY liner when I get the time.
A few quick pics of the Line X. Happy so far. I have used the raptor product before and was happy with that also!
Still looking for a nutmeg back seat!! :shrug:
IF I were to line my Jeep I would go with Line-X. It looks fantastic and holds up great. I've heard good things about the raptor liner but I haven't seen it in person. I've personally used Herculiner and it was ok but not nearly as nice as Line-X. All that being said, if you ever want to "restore" the Jeep back to original or just remove the liner, good luck. The stuff (any brand) is a serious PITA to remove. Just something to consider before you do it.
Liner:
Paint:
Line-X! My Scrambler and Commando are both Line-X and I love it, tough as nails. Will do my M715 bed and interior once I get the dynomat sound deadening/heat blocking treatment on the floor.
If I had YOUR money , I would burn mine !!!
