Shop addition 30' x 40' - Adams Family Scrambler World HQ
What's the thinking behind the outlets up high on the wall?
Ones on our west wall are on a single switch and will be for beer and Jeep lights.
Ones on the opposite wall will be accessible from the loft/mezzanine, that will be coming up after the ceiling is complete.
The loft/mezzanine will be 8' deep X 40' long and have just under 10' clearance underneath.
Medium height outlets are for some TV's
Ceiling install is pretty much complete. Just need to tape the seams and finish a small area at the peak.
100" ceiling fan installed.
All taped up in this section. Using aluminum tape on joints and over the screws/washers.
Ripped some OSB to trim out the walk thru door.
Also trimmed out the inside edges of the windows with OSB.
That is some serious storage space. :thumbsup:
Is that 16" or 19.2" joist spacing?
Decking installed less 1 sheet.
Got to the bottom of pile and here is this purple painted sheet, not acceptable since I plan to leave natural.
Knocking out some of the smaller items. The stainless sink from marketplace was a bit to short for us as is.
Decided to ditch the legs on it and just build a frame to sit it on.
Will probably cut some OSB for doors on it.
Also built a cover to hide the main electric that came up thru the floor and into breaker box.
awesome. Are you going to flash the right side wall next to the sink? I could see that becoming a problem area with any splash or overflow.
