Shop addition 30' x 40' - Adams Family Scrambler World HQ
Finished installing the SnirtStopper garage door seal on all garage doors on old shop and new addition.
Up next garage door opener. Be my first jackshaft style install. This came from Menards.
All the parts/pieces laid out, looked a bit intimidating but install was not that bad.
I plan to eventually purchase 2 more.
I did get the lift topped off with fluid and it is working. Have not got a vehicle on it yet.
Snagged this cool picture at night from the road.
Started throwing a few beer lights and misc. items on the walls.
How/where do you install the Snirt around the doors?
I tried a jack shaft opener, it was was more trouble than I wanted to deal with. One of the major drawbacks is it does not pull the door down, so if it does not have enough weight in the vertical position it just unwinds the cables from the pulley. I tried the spring pushers mounted to the track to shove the door off the horizontal track and it still was not reliable.
I hope it works out better for your application.
Up next was getting everything out and getting the floor prepped for the Ballistix "Conquer " floor coating system.
Scrubbed entire floor with simple green and another degreaser. Followed by Ballsitix "Obilterate" cleaner.
All cleaned up!
Filling the concrete relief cuts.
Taped each side of the cuts.
Filled with RS88
After razor scraping.
Wiped entire floor with 99% Isopropyl. Then applied Ballistiseal Advanced sealer/primer.
We had enough for 3 coats. Waited approx. 45 minutes between coats.
Finished one coat Black Label with satin pack.
