Some observations from last night...
1) My bottle of windex was frozen solid... it has ammonia in it, which I was led to believe in chemistry class didn't freeze, but alas... I either have cheap windex, or it is too cold.
2) It isn't the coldest it has ever been up here, but it is the longest prolonged time... thus a lot of things won't work... I can't charge my drill batteries outside, have to bring them into the house, let them warm up, then charge them, then outside.
3) Cold Galvanizing weld thru primer... can't be used in this weather if left outside... bring inside and warm up gradually, then bring out when needed.
4) When opening a beer, you had about 2 mins to finish it, or it froze into slushy chunks
5) With the wife laid up, that stove is being plugged full of wood and we are burning through it at an alarming rate... it is warmer in the house than normal though.
6) cutting/grinding/welding in the cold is next to impossible with glasses on... since my eyesight has decided to go in another direction, I wear glasses under the grinding or welding mask... and it fogs up quick.
I do have a heater out there, but when it is -11, it just doesn't keep up... just takes the chill off... the good news is we have a small break tonight and tomorrow for a small warming trend, then back to deep freeze and then next week back to more normal temps.
You are always more than welcome to come up, but I would wait till it is a bit warmer as my conditions aren't that much better ')
