Snow Chains - Northern Guys Chime In Please
CJ8LVR
Madison
AL
We don't see it real often in Alabama but when snow does come to Alabama - it tends to shut things down because we don't have / use the equipment y'all do. That being said, id like to hear some suggestions on snow chains for a 31-34" tire size range. Brand, design, where to ORDER etc. Won't have them in time for this event but would like to be prepared for the next. Thanks guys.
I've had LaClede tire chains, can't remember where I got them. Used them a couple times when we get really dumped on. CO is a lot like the south, we don't plow a lot here and just depend on the sun to clean up. That leads to some interesting days where the entire front range is shut down.
They're expensive, not sure I'd recommend them as unless you have more than a foot at a time, you can probably get by with 4wd. I never needed them when I lived in NY, only after I moved here and we got hit hard and the county couldn't handle it.
Hey Jake. Meg said it snowed there yesterday. Have fun in the $5.
She drove mine for the first time Sunday. Her exact quote is it will take a bit of getting used to.....
Talk to you soon.
For what your going to see down south, you would be better off with the Cable type traction aids.
they run quieter, wont damage the tire as easily, or the body work, and are less expensive, at least the last time I looked at them they were.
another option, for the guys in Colorado and areas they dont spread anything but sand (no salt) would be the 'Green diamond' type of winter tires.
they have a grit mixed in the tread rubber to aid in traction. this is especially usefull on icey condition in states where tire studs are now illegal (most states by now).
as for where to buy, try trucking supply comany's and places like tractror supply or Northern Equipment.
Maybe a stupid thing to say, but check on the legality of them first. Here in IL you can't use them, we're at the mercy of IDOT (the chains, that is. Studs, too).
I've never used tire chains. I remember helping my dad put chains on our early '80's Buick back in the day but I would say good driving techniques and 4 wheel drive will get you just about anywhere you need to go. Just my :twocents:. BTW, we currently have about 6" of fresh snow on the ground and the City is only plowing major streets. We are getting around fine (I drive a Toyota Tacoma 4x4 and my fiancee drives a Subaru Outback AWD).
Yea, Illinois has some strange ideas :crazy:
I think its from drinking the Lake water :rotfl:
Every state has its laws, most at least have a snow depth 'range' for chains/cable use. In almost all the midwestern states they are just not legal though.... :( :angry:
I wouldn't bother with them in the south unless you're in higher country. Around here even the worst of snow is gone in 3 - 5 days and I've always been able to get around in 4 wheel drive, and most of the time 2 wheel drive in the Jeeps will get me around on primary roads.
Jake, I bought a set for my truck years ago from tirechain.com.
They are still sitting in the same bag they came in, unused. They do have a lot of travel miles on them though, they go with me whenever I travel during the winter months.
You really don't need them down there. When I lived in Colorado, I used to chain up the CJ at all four corners for some of the icier trails we would hit. Other than that, I didn't need them for the snow wheeling.
I'd put money on them being illegal. They can't have idiots running them year-round and tearing up the roads. Also, as soon as you have them, you're guaranteed never to see snow again in your lifetime.
This is why you have a Jeep in the first place. Putting tire chains on a Jeep is like putting galoshes over Gortex boots. C'mon man. :banghead:
:rotfl:
since we are on that topic.
<object width="480" height="385"><param name="movie" value="http://www.youtube.com/v/d5exATIaQiI?fs=1&amp;hl=en_US"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/d5exATIaQiI?fs=1&amp;hl=en_US" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="480" height="385"></embed></object>
Did you notice the only thing that made it through was the Jeep (TJ).....:popcorn:
Yep. but the liberty didn't. and the F250 @ ~6:00 woulda made it if he hadn't stopped at the top.
I was watching that (and noted the TJ make it) and I was yelling outloud at the guy in the F-250 "Don't stop!", but he did and it was all over!
If you have a four wheel drive you certainly don't need chains for any snow you'll ever see in the south. When I lived in South Dakota we usually had packed snow on the roads from November to March and I never needed chains. They don't use salt, and it's too cold for salt to do any good anyway, so once the snow is on the ground it stays until it melts or gets blown away. Here in DC we had back to back 24"+ storms last winter and my Scrambler with 33" BFG AT's handled bumper deep snow with absolutely no problems whatsoever. Very unlikely you'll ever get more than 24" of snow in the south, but if you did just stay home a day or two until someone breaks trail, once there's a set of tracks in it you're good to go.
Chains are great if you have a two wheel drive rear drive vehicle and you are driving in a foot or more of pure snow. The are really lousy when you get into town and someone has plowed the road. I've never needed them in a Jeep.
Thanks for the suggestions guys.
I should have specified earlier an important point: our local 4wd club has been called upon in the past to help get doctors and nurses in to area hospitals and some of us have pondered snow chains to help us ensure that this happens. There are some pretty good mountains around Huntsville that never get plowed and we have a lot more freezing rain / sleet mixed in with these systems that occasionally move through. If they were just pure snow, y'all are right - it probably wouldn't be all that bad.
One other situation we have is that we came above freezing just a little bit today to start some of it melting but it dropped back below freezing around 4:00 PM and is forecast to go down into the middle teens tonight. Tomorrow, every bit of that nice packed down snow from everybody driving on it today when it was slushy, will be a sheet of ice tomorrow morning. This city is pretty much shut down. I've driven in it plenty in the past two days and haven't had too much trouble in our Grand Cherokee or the Scrambler but I've not been called upon to traverse any of the mountain roads. We've had a few other club members do so and they say it's very, very slick.
That said, here's a little video contribution shot in Atlanta.
Note the Jeep. :thumbsup:
<iframe src="http://player.vimeo.com/video/18654578?title=0&amp;byline=0&amp;portrait=0" width="398" height="224" frameborder="0"></iframe>
For what you are trying to do, tire chains on all 4 wheel positions are the way to go. Cables are quieter and better to use in close tolerance situations...but they don't grip as well as chains in deep or loose snow. The best chains are commercial grade with the "vee" links in the chains. I don't think you'll use them enough to justify spending the money on commercial chains.
Chains are just as important, (or more) when stopping as they are when starting out. Chains with the vee bars are most effective when driving on ice.
Jeeps with mud tires or rock tires are of very little use in snow. I have 35" MTRs on my TJ and they do not work well in the snow, the lugs load up with snow and become slicks. All season or M/S tires are better than rock crawling tires. Winter tires are a softer compound tire that are much better - at a great cost.
Best way to find tire chains is to google - "tire chains". www.vulcantire.com and amazon.com sell chains at a competitive price. You can read about the types of chains on the Vulcan tire website.
I bought comercial chains for my dually from Vulcan tire for around $135, (rears) with free shipping. I bought the fronts from amazon.com for about $100 with free shipping. If you can, put them on and leave them on that vehicle while you have the snow conditions that warrant it. Make sure you use the chain tighteners, which aren't included in the cost of the chains - usually. Practice putting the chains on while you have dry pavement....you'll be glad you did.
I don't claim to be a tire chain expert but this is what works for me & others around here.
Never used chains, and we get lots of snowy/icy days each winter. BFG A/T's are hands down the best, with General Grabber AT2's a close runner up. I will say the BFG's even outperform studded tires.
That video was insane! But I've driven roads like that in my Scrambler and in my XJ with no problems. You just gotta remember...no sudden moves, no rapid acceleration or braking, and don't stop on a slope. Airing down some helps too. I do carry a bag of small bag of gravel/kitty litter mix, in case I need to "make" some traction.
Rock-N-Roll - You forgot to mention that here in the Colorado mountains, chains are often REQUIRED by law to travel the high mountain roads. Something that you don't see hardly anywhere else in the country.
Got to love the steep mountain roads with big drop offs and no guard rails!
