1x1_Speed_Craig
Simplify...
- Greeneville
- TN
DISCLAIMER: This is the tentative plan, but it's looking pretty good at this point.
Charity tub update...
After trying for several months to work out a deal on a particular rust-free OEM Scrambler tub, the deal never materialized. The SOA planned on buying this tub, with the funds to be replenished via some of the raffle ticket sales. This was necessary, as we were unable to round up a donation (understandable, given the rarity of solid OEM Scrambler tubs).
As many of you know, I purchased Butch's (lineforeman99's) old rust-free, but slightly damaged, OEM tub for my personal Scrambler project a couple months ago (see attached photos). This tub is located in Colorado, about 3 hours from Moab, UT. I also recently purchased a rust-free tub in Texas. If you excel at math
, you'll realize that I now have one (1) Scrambler project and two (2) rust-free tubs. Therefore, we will plan on using the Colorado tub for the SOA Charity Scrambler.
So that everything is out in the open, the SOA will be buying this this tub from me for what I have into it (significantly less than what we had planned on spending on the other tub). While I would really like to donate the tub...
The plan will be to transport the rolling frame (frame, springs, axles, wheels/tires & motor/trans/t-case) from John N's place in Virginia to Moab for display at the SOA National Event. Butch (lineforeman99) or one of the guys out his way can probably transport the tub from Montrose, Colorado to Moab. We already have a M.O.R.E. body mount/1" BL kit to use to attach the tub to the frame. With some SOA member help, we can probably have the tub, windshield & front clip bolted on in the matter of an hour or less. Hopefully, I'll be able to round up someone in Colorado to repair the rear corner prior to display. If not, the magazine(s) can photo it from its "good side"...yes, we're working on getting magazine coverage of the project.
Craig
, you'll realize that I now have one (1) Scrambler project and two (2) rust-free tubs. Therefore, we will plan on using the Colorado tub for the SOA Charity Scrambler.So that everything is out in the open, the SOA will be buying this this tub from me for what I have into it (significantly less than what we had planned on spending on the other tub). While I would really like to donate the tub...
- Unfortunately, I cannot afford to do so at this time.
- I have donated (and will continue to do so) a considerable amount of parts/time to the project already.
Craig
sorry! I do have the stock shackles and will ship them up for the build if I can't be there and you still need them.
Right John?
That definitely hooks us up, as we needed one prior to the February work day at John N's place.
