SOA Charity Scrambler-The Assembly
Gee Canz, hangin' out w/ you... no wonder I have wifey 'issues'...
canzo said:
[...]Might have to bring my daughter along, but as I always tell her "it'll build character" or make you a character - something like that. At least we'll have someone to help cook, fetch beer, and serve food...:eek: male chauvinism alert :eek: ...[...]
I'll try to make it... give ya guys a 'tentative' answer NLT the evening of the 17th... :rolleyes: But please don't hold me to that!
Now... about that food thing............................. :D
Fed-Ex, the company not the member:D , delivered the new flywheel today:D . Bolts to install??
A little progress today...
I wanted this painted before the work weekend.....
Got 2 cans sprayed on the top side, need to flip it....
I hope to get it flipped and spray the other side tonight.
Maybe, start on the springs tomorrow.
The frame has been flipped and painted, just drying at this point. So, on to smaller parts.
A realization today....WE NEED A STOCK SKID PLATE/CROSSMEMBER AND TRANS MOUNT.... SOON!!! Hey Ted..you got one laying around? Need this ASAP. I want it cleaned and painted before the work weekend.....and yes, I looked under the donor and there isn't one there.
John,
If Ted doesn't have one, I have a couple around here. Shipping would be pricey due to the size/weight, though. Just let me know if you can't round one up near you.
One of mine has been cleaned up & painted by a previous owner, but could probably use a once-over with clean-up/paint, as it has been sitting around for a while. There would be minimal work in getting it to look good.
Craig
I think I have one for 80 - 86 frames,I know I have 4 or 5 for 79 and back,I have a box of transmission mounts.I guess you just need the metal channel iron part?
I have a skid plate on a frame that I have. It is out in the yard. I just need to filp it over and unbolt. I could get to it sometime this week. Not sure when I could get it to Richmond, but if someon eis going that way, or comming this way I can make it available.
What Transmission, I might have one but would be a long shot that it is actually good.
Carl
Thanks Ted, see if you have it and give me a call. I'll PM you my #.
Scott I'll PM you my address, too.
Carl and Craig, lets see if Ted has one, since that would be local.
The trans is a T176, I'm not sure what the mount set-up should look like.
I have one,what part of the tranny mount is Scott sending?
I think Scott is sending the entire mount, less the torque stud (said this was gone/missing). Can you meet me somewhere, so I can have it painted the same as the frame, before the work weekend? Thanks.....
I spent some time today making sure my Tetnus shot was still working. I pulled a few parts off of the donor, so they could be cleaned up and painted. I got the sway bar and all of it's related hardward pulled and the front shock mounts (wide track style). Other than needing a new bushing set, the swaybar will be good. The shock towers are too rusted to be used and won't be worth the effort, they've got holes rusted through, once I knocked all the crud off of them.
SO.....who has front upper shock mounts (these are the taller ones held on with 3 bolts)? AND we need a bushing set for the swaybar?
ted...what i sent was everything but the torque stud and bushings....i sent torque arm and rubber molded trans mount...i can probably come up with the torque stud and bushings at work if we end up needing them
I saw a torque stud around here today,the rubbers looked like new on it(I think).
John I don't know when I could meet you,the piece of crap company pickup truck is dying,I hope it will make it to southside tomorrow to drop off a dana 30 at USF trucking,plus I have 2 rears to build,with 3 more due in this week,and I'm not hauling it in my CJ-7.Richard will be by here in a few days,or sooner,he probally can take it to his work place,or meet you somewhere,or you can come here.If nothing else Nick may be able to meet you somewhere this weekend.
Either would work....
