Finally got some time to mess with the CJ6 without having to run off for something else. Messed with the switch started once then not again. Took the switch off and plugged every thing back in and actuated it by hand Jeep started. Put it back on wasn't set right not in sync with the key position, took it off reset it to right place and tried again every thing seemed correct with the key activating like it should but not turning over. Back to the drawing board (now remember I am not a pro mechanic). Thinking to my self why is it, I have checked every pin on the switch with meter and it should be working. Then it hit me. I don't have a boot over the floor shifter and the neutral safety switch is there, 12V to the starter goes through it, so I put my meter on the switch and tried it again and low and behold there was 12v there. Then it hit me like a hammer I have been barking up the wrong tree. Went down to my favorite independent auto supply shop and ask for a starter solenoid. He looked it up and told me he could get me a new starter and solenoid for what it cost to get just a solenoid. I said you are kidding, he said no! The solenoid listed for $90.00 the starter combo was only $50.00 so took the new starter and solenoid and ran. Installed it, turn the key and it cranked over. YEA......it did not start. Ok why did it not start. Check voltage to the coil none! Started digging through paper work where does the 12V come from. The starter switch, to the fuse block, to the coil. OK fuse block, check it. While building this Jeep I added a piggy back fuse holder to power something else and messing with everything under the dash I had pulled this out of the fuse holder, it had been plugged into the coil position, plugged it in, hit the starter the rest is history now.
Just a reminder check the easiest thing to replace first!
