A bunch of disassembly pictures, brief notes.
The yellow plow blade, and all of these other parts are heavy. Work smart, use your head, very easy to get hurt bad/quick. Use the hydraulics to help you, and jacks, cribbing, pry bars, etc. No worse then dealing with tractor implements, if you are familiar with that type of stuff.
I removed the two springs on the back of the blade, laid the blade down:
Remove the two big pins that hold the yellow blade to the carriage:
Used the hydraulics to raise the carriage off the blade:
Removed the lifting chain, disconnected the two hydraulic quick connects, and then the two big bolts that hold the blade carriage to the Jeeps frame bracket, backed the Jeep away from the carriage:
This next part is a bitch, unless you drop the front shackles off the frame. I did not have to do this, but a big PIA.
I jacked the frame up to raise the suspension, and disconnected the sway bar to get some room. Four big bolts hold the carriage to Jeep sub frame assembly.
Then, wiggle worm, curse, shove, get the sub frame out. This part fits tight between the leaf springs, and then has wings that go outward. So, you have to twist and pull and curse and it will come out, but sucks with the leaf springs in the way, but doable:
Looks like progress!!!
