Spec'ing out my new Engine
ScramFam
Registered User
Nowhere
OH
Never thought I would do it, but I'm not getting enough power out of my AMC 360. Any ideas on motor mounts and adaptors?
Now that the funding for NASA has been cranked down a notch, I think they've got some mounting kits available.
Don't forget
Along with the additional POWER you will also be increasing the gross vehicle weight. You MAY need to upgrade your axles as well. Possibly DANA 44s. You may also want to consider a 25.5 ton winch upgrade for the front just to help get you yo the top of "Test Hill" with the additional load. :crazy:
Have you figured the Horsepower to weight ratio? :eek:
:thumbsup: :wave:
Good points. I guess I should consider a plan B. Will the OE teardrop air filter work on this? I want to keep my Scrambler as stock as possible.
Factory look...
Doubt the tear drop would work on that monster. If your trying to keep it factory stock..the tear drop is a bolt on for the AMC Flux Capacitor! Less weight and more...
ZOoooooooooooooooooooooooooooooooommm!:thumbsup:
you might run into a cooling problem. Last time we did this swap we took the electric drivetrain out a of prius and the propeller off a spitfire. Worked perfect. not much hood clearance though.
What did that come out of? A '37 Packard? Looks like a pretty standard straight eight to me.
Both engines are D-Troits (Detroit Diesel). The engine at the top of the post is most often used for marine and generators. The engine later I believe is a Series 60. I shot them both on tour of their manufacturing facility.
