The Banana Boat
This is an antique dwell meter and "tuning" device- 😎
Sent from my SM-G920V
That is awesome :bow: :thumbsup: :cheers:
All I have is an old Analog Sears Dwell/Tachometer, but I love it :cool:
You guys are scaring me.
I went out and messed with things a little today. But I left the distributor alone. I wanted to triage the heater (or lack thereof) and the problematic power windows.
As for the heater, with the key on and the fan speed on (all speeds) I have power on all three prongs of the Heater Resistor). So to my pea brain, it seems like power is going in and coming out of the resistor. But since the next piece of the puzzle is the blower motor, I am going to bet that is the culprit. Not exciting news. I was hoping it was the switch or the resistor. The blower motor in the impala is not as accessible as in the Scrambler. It is under the defunct AC unit and you need to remove the inner wheel well to get to it.
I also took the door cards off and greased up the window tracks. The driver side regulator has flat teeth at the end of the gear causing the window to not go up all of he way. Put a new regulator on the list. The switch on the passenger door does not work as well as the switch for the pass window on the driver side door. No biggie. At least greasing the tracks helped a bit.
So not a very productive day bit a little investigation done.
Now to swap out a xenon bulb in the Audi. Fricken expensive bulb and German engineering requiring me to take a lot apart to get to it. Grrrrrr
They engineer it that way so you bring it to the dealer, so they can make some money. They don't want shade tree mechanics working on their high priced steel
Sent from my iPad
Sent from my iPad
Yeah well, too bad for them. Done. And I went ahead and solved something with the bumper that has been bothering me since we got it back from the body shop spring 2015. They left off a bolt that held the bumper cover tight under the head light. Damn them. How annoying.
Thanks John. Sure. Not sure how we can get it arranged, but I am driving through Richmond area for Thanksgiving at my parents place in Hampton.
Thanksgiving day would be difficult, we've got 40 plus for dinner....unless you just show up to eat like everyone else. Maybe on your return trip.
I might have missed it but when was the last time the carb was rebuilt? It's acting like the accelerator pump isn't working at all when you open the butterfly. Try opening it all the way with it not running while looking down the throat. you should see it squirt fuel into the throat if not then you've got a problem either getting fuel to the carb or the accelerator pump is shot.
And you need to check the timing
Agreed. I will have to do that. That is one of the things I don't have confidence about. Definitely need to do that when I install the HEI anyway.
I just got the car an have no idea when or if it was rebuilt. I will look at the squirt.
No worries John. It would not be today. But have fun with that dinner. If I do swing by, it would be Sat on my way home.
I gotcha man. You're probably going to have to rebuild the carb prior to being able to time it. You need a pretty much rock solid idle when you're setting it. How much do you know about the quadrajets? Be careful not to flip it upside down it can make the metering rods fall out from what I've been told. But it's imo one of the best carbs around. The poor mans fuel injection
Never rebuilt one. But had one on my 69 GTO and never had a problem. Loved that carb.
There are a lot of "updates" you should do to it if you rebuild it. 😉
It should be a enjoyable project for y'all. There's several videos on you tube explaining the whole process and there's a website dedicated to the quadrajet. http://quadrajetparts.com that has some decent information and parts
Family friend (and original owner of my old GTO) was at dinner with us today. He suggested still running a vacuum test on the manifold and check the timing. Also to rebuild/improve the q-jet. Looks like we will be digging into stuff this winter.
Thanks guys.
Wow, interesting thread. I had a 68 impala years ago. Pea green and rusted out rear window surround (thanks to a vinyl top). Was a fun car until I got hit by an uninsured illegal who ran off after hitting me. As I remember it had a TH350, not a 400. Mine was a 327 w/fresh 350 heads and a 4bbl quadrajet.
Sorry to hear that you lost it that way. We are learning a lot about this car and Chevys in general.
Yeah, its in my list of sad history vehicles. Should have kept it and fixed it up, especially knowing now the value of 2 door 60s cars. :( right up there with my first car bought off my parents. A 69 Caprice 4 door with a 396.
As I think about it, check the door hinges on yours. The doors are pretty long and heavy which can wear the hinges out. Also check the rear windshield trim area. The stainless is a dirt magnet which will cause rust.
One of my first cars was a 63 Impala SS with a 409. Never really knew what I had other than it did great burnouts. Sold it for the proverbial song and have been kicking myself ever since!
