Transmission Question for 5.3 swap
The ax15 in basically a Toyota R series transmission. Basically the same found in the supras and v6 pickups. And there are plenty of 600hp supras driving around. My buddy is currently beating the crap out of his 450 hp chevy 350/ax15 swapped rx7 and it's holding up great. I also had a 94 toyota truck that I absolutely tortured and it held of great. In my opinion they are very underrated. I have blown up 4 700r4s, 1 2004r, 2 4L80s, 2 T5s, and 1 T150. My R series lived just fine through way more hell than any other vehicle I have owned. This is my own experience with this, I think they're great. If you really have your doubts then go with the 4500.
This was my NV3550. I had an adapter plate to a standard GM bellhousing, and a factory spacer for the flywheel. That way a stock hydraulic clutch from an Iron Duke will fit. Or go with an aftermarket housing/slave cylinder unit.
241OR end...looked like a D300 would bolt right up.
Overall...
Transmissions don't just get a torque rating; it is a torque rating at x weight (GVWR). Here are specs for some of the manual boxes talked about on here:
ax15 300ft lbs @ 7000 lbs
nv3550 315ft lbs @ 7300 lbs
nv4500 460ft lbs @ 16000 lbs
The weight rating is important because it allows an actual resultant force calculation for the overall vehicle drivetrain. Meaning size and type of clutch you need, u-joints, drive shaft diameter, etc...
As another anecdote:
I just put an nv3550 behind a Ford 5.0 in my scrambler. The engine dyno'd at 385hp/380tq which is over the 3550 rating by a good bit. But the vehicle weighs just under 3000 lbs with full fluids, and will likely never see 7000 lbs GVWR. Since I have not upgraded axles, u-joint size, etc.. I suspect many other things would break before the tranny if I loaded it/towed that much and beat on it some.
The NV3550 was not only used in Jeeps behind 4 and 6 cylinder engines, but also in V8 powered Dodge Dakotas and Durangos, light pickups, and by GM as a NV3500 in S10 and full size pickup lines both with V8 and V6 engines. I currently have one in my K2500- granted it's behind a 4.3 but it has 211K on the clock and it's still tight and quiet. The GM and Dodge fullsize units had integral bellhousings, but the intermediate Dodge and Jeep versions should have bolt on bellhousings. (Please double check this before buying sight unseen- I went through several dead ends because Dodge does funny things...I have found all GM's had integral bellhousings and all Jeeps had bole on bellhousings.)
The point of this is that the factory believed the NV3550/3500 to be stout enough to use in vehicles a lot heavier than our Scramblers.
I am so tempted to install a NV3550 behind a fresh 4.3 in my red Scrambler, because I already have the 4.3. But there's' nothing like a V8...
A lot of good points have been made about the nv3550 and ax 15. It sounds like they hold up better than I thought they would. Having to do less fabrication is a huge benefit. Is it possible that the new ax15 from Novak is the same the "terminator" from rsg? Both talk of increased strength but not really how they get the increase. I thought the hardest decision on a swap would be a motor not deciding on the transmission. Hearing that others have had good luck with these transmissions makes has changed my mind.
This won't be your last decision you'll have to make by a long shot. For every choice you make today you will create three more in the future. Wiring harness, gauges, sending units for the gauges, radiator, then hoses, motor mount, cross member, drive shaft, CV joints, people who say you made the right choice and people who say your crazy. That's where all the fun in building it like you want is. I wouldn't have it any other way.
If you use that 4.3 in Red I'm going to hit you up side your head with a 2 x4. LOL
Don't worry...LS all the way. We can't have twins if mine is underpowered...
I purchased a new AX15 from Novak back in the beginning of 2014:
I replaced 3 blown up T5's with this AX15. At the time, I wanted an NV3550 because of the slightly deeper first gear. That was my biggest issue with the AX15, first gear was not deep enough.
The AX15 I bought from Novak has the deeper first gear, the ratio's seem really similar to the T5's, which I like. The guy at Novak I talked to had to "dig around in the warehouse" to find one of the deeper first gear versions, they might not have many left :shrug:
My AX15 is not a "Jeep" version, I believe it is for some type of medium duty Toyota truck, JDM maybe :shrug:
More information:
http://www.pirate4x4.com/forum/jeep-hardcore-tech/746537-4-3-1st-gear-ax-15-a.html
http://www.pirate4x4.com/forum/toyota-truck-4runner/714909-gear-drive-t-case-r-series-trans.html
When I say "deeper first gear", I do not mean granny gear. Mine has the 4.something first gear, as opposed to the 3. something first gear. Might not sound like much, but it is similar to "high" first gear of a T176 compared to the "low" first gear of a T5.
So far, I have been happy with this AX15, or what ever it is :rotfl: But, I have not put that many miles on it, maybe 5,000. Time will tell :thumbsup::wave:
I am looking forward to getting started on the swap but right now just trying to get a list together of everything I think I need. Seems like the list keeps getting longer and longer. I would like to try and get as many parts as possible before pulling the current motor. I started reading as many of the build thread as I can to try and get a a good plan of what I need to do. I have never tried a swap like this before but feel that if I take my time and read as much as I can I will be able to do it. I am sure that I will be posting a lot of questions in the near future. Luckily my wife likes the jeep and wants to be able to take it on camping trips so she is all for the build.
This may be a bit of a help. I put a list together for my swap and gathered up parts and the problem I ran into was that I either changed my mind on some of it or the parts just were not a match so I ended up buying a lot of the parts twice. Swaps have been done thousands of times so I doubt that you will run into any problems that can't be solved by someone here. Take your time, buy it once and you'll only have to cry once.
I run the NV4500 behind my 5.3l.
The way i see it, build it right or build it twice!
Hey, I just swapped my 5.3l to an nv4500 from a 4l60e. Something is a little funky, would you mind if I picked your brain on parts and what all you did?
for sure
I did the 5.3 with an nv4500 and it has a lot of drag in the lower gears with the clutch depressed and shifter in gear. Do you experience this also?
My 5th gear and sometimes 4th gear also rattle a lot at regular speed driving on the highway for example. Do you also have this? I tried a new shift tower and nothing changed.
Those first two questions are mainly I don’t know what the NV is supposed to drive like and seeing if those are normal.
Now into the meat and potatoes. I have a fair amount of grinding which is my biggest concern and the reason for the questions. if I shift quickly from 1st to 2nd or occasionally a regular shift from 2nd to 3rd and 3rd to 4th.
My NV was freshly rebuilt along with my transfer case prior to install. So I am wondering what clutch system you are running. Internal or external slave? And what you used as a master clutch cylinder.
I am trying to figure out if somehow the synchros are bad after less than 9 months driving around or if I am having a clutch hydraulic issue. The grinding problem popped up about two months after install.
Any help you can provide would be greatly appreciated.
Thanks,
John
Mine had roughly 1,100 miles on it when I bought, so basically brand new. No issues like yours at all. No noise or grinding.
I'm running a heavily modded mechanical clutch linkage built using stock CJ parts. I have a throw out bearing from an early 60s Chevy Bel-air with a inline 6. It was the only one that worked in the bellhousing.
I was planning on this just being temporary but it works perfect... 12 years and probably 20,000 miles on it.
@Jhp243 I have an early Chevy NV-4500 with the 6.34:1 first gear. Been in there since 1989. I got it from JB Conversions at the time.
What do you mean "drag"? If you mean it tries to creep forward when the clutch is fully depressed, mine does not do that. I had a CJ-7 that did.
The guy who helped me on my 350/NV4500 swap said he swears by the Borg Warner Brute Power 90100 clutch. So we put one in back in 1989 with the swap. I never had any issues. When I did my Scrambler rebuild/refresh, since we had it out, I put a new 90100 kit in and it works great.
Very smooth.
I don't have those rattles. While in gear and under power, if you put pressure on the shift knob it will vibrate a little bit. Let go and it stops.
With my low gears, I don't use first gear on the street. I start out in second gear. If I fully depress the clutch pedal I don't get any grinding. It is a long throw of the shift lever so you really do need to keep the pedal down until fully in the next gear. My wife has a YJ with an AX-15 and that trips her up when she drives the Scrambler.
I have an external slave cylinder - I believe it is the factory Scrambler 4-Cylinder slave and master. Not 100% on that. It was a long time ago that we did the 4 cyl to 350 V8 swap.
Are you using a fluid compatible for the NV4500? There are only a few fluids that work with it to avoid the brass syncro's from breaking down. (so I'm told) I use Amsoil 75W90 Manual Transmission Fluid. https://www.amsoil.com/p/amsoil-75w-90-manual-transmission-transaxle-gear-lube-mtg/
Thanks,
John
Thanks for all of the help, I also have an earlier nv4500. When street driving I do not use 1st gear. What I mean by drag is I can hear and feel that even though the transmission is not engaged when in gear with the clutch depressed it is almost slowing me down. I don’t know if that makes sense exactly. It doesn’t try to creep but when coasting to a stop it definitely has some resistance almost.
I have a centerforce clutch. I am not exactly sure which one but I could find it if needed. It is an off-road type clutch for their 4x4 option I guess.
That is the weird thing. If I shift like normal not too fast not too slow it will only grind sometimes. If I shift really slow it will not grind. I also had my dad drive it and he said that he thinks the clutch feels good as far as engagement and disengagement goes.
As for the rattling I don’t know what to make of that. It just rattles a lot in 5th and 4th especially. If I push the shifter to the side or anything it gets louder but I cannot put it in a spot that gets rid of it.
We converted my trans which was an early model external slave to an internal slave. We machined the bearing retainer off of a late model internal slave to fit and drilled the holes to fit the bellhousing. We did this because I wanted to use a Silverado clutch setup since that is what my 5.3l is out of. Thought that keeping everything factory as far as a clutch setup would be the best idea.
I’m leaning towards I have a synchro issue or possibly clutch issue.
I originally was running redline mt-85 fluid which is gl4 rated and recommended as a close factory replacement for the nv. I started to get some grinding so I changed the fluid and replaced with the same mt-85 oil. I experienced no change so I went with the amsoil gl4 which I believe is a 75w90. I also experienced no change.
Now I’m here, I don’t know what to do to fix this issue and it’s very frustrating every time I drive it having these issues because I did everything as close to factory as I could and everything lined up absolutely perfect. I just don’t know how to fix it.
Thanks for all of the questions and responses I’m getting on this.
Very smooth.
Has the 5th gear nut backed off? That is usually a problem with high vibration diesel trucks, not gas engines though.
