VIN locations?
Orionn
Vehicular Packrat
Ann Arbor/Ypsilanti
Mi
:confused:
Where is the OEM VIN number stamped on the frame or anywhere else?
My scrambler has no VIN plate, and has a state issued VIN and Body sticker.
(it was a re-assembled basket case with no title at some point)
I'd like to rectify that if possable
thanks
4miles
Virginia Beach
VA
Vin
The only places there was a VIN when I tore mine down was a sticker on the body under the driver door, a riveted tag with VIN and other information under the wiring harness on the firewall and another riveted tag on the wiper motor cover. Nothing on the frame.
jscherb
Elmira
NY
I rebuilt an '83 frame last year and found the VIN stamped on top of the frame rail on the passenger side hump above the rear axle.
4miles
Virginia Beach
VA
Frame Vin
Jeff is right....... I just went and checked mine and it is barely legible, but it is JC and the last digits that match the VIN for the body.
"1975 to 1986 Jeep CJ VIN numbers are usually located in several possible locations. You should find a tin plate on the drivers side firewall near the brake master cylinder. You may also find one on the drivers side dash or the inside body panel by the floor near the parking brake lever. On mid 80's models it should also appear on the windshield wiper motor cover inside the Jeep. An abbreviated version is usually found on the top of the passenger side frame rail above the rear wheel."
rustycrawler
Reston
VA
There is/was also a tag on the firewall under the hood to the right of the steering column.
ilovetrains
slightly backward
Lee's Summit
MO
At this point I have completely stripped 3 Scramblers, 2 81's and an 83.
All 3 had a the dash VIN tage on the wiper motor cover.
Not one had anything stamped on the frame. 1 81 frame was pretty bad, so it is possible something was there and just rusted away, but the other 81 and especially the 83 were in pretty good shape and neither had any stmap on them.
None of the three tubs had any VIN markings at all.
None had a VIN sticker. 2 had a manufacturer sticker but it did not have a VIN on it.
SO basiclaly I am yet to see one with anything other than the dash VIN.
Joe West
Arizona Virtual Jeep Club
Laurinburg
NC
My 1982 has the vin on the passenger side frame, on a sticker just below the driver's door on the body, and of course, on the dash plate.
JeepScrambler
CJ-oholic
Claflin
KS
My CJ's have the vin number present on the firewall under the master cylinder, below the inside lip of the driver's door on a decal, the wiper motor cover dash plate, and stamped on the top of the passenger side frame rail above the rear tire.
The decal under the driver's door is most likely to not be present out of all the options (due to being removed, adhesive failing and it falling off, or painted/bed lined over) and the stamped vin number may be hard to see due to paint or rust but it should be there.
gpassida
Silver Member
Redding
Ca
Sorry to resurrect a 20 year old thread...
I've got my Scrambler down to the frame now. Preparing to paint it.
I found this on the passenger side frame rail on the hump.
Does this mean my 1982 Scrambler was #5721 produced that year?
ag4ever
Average Nut
BENEFACTOR
Silver Member
Richmond
TX
Should match final numbers in vintage (vin, not vintage. Darn auto correct) and means it was the 5721st jeep off line. I believe all keeps (jeep, darn it again) were counted in that. CJs, Wagoneer, J trucks, etc...
gpassida
Silver Member
Redding
Ca
Should match final numbers in vintage, and means it was the 5721st jeep off line. I believe all keeps were counted in that. CJs, Wagoneer, J trucks, etc...
Thanks. It does match the last 4 of the VIN.
Flatie46
Russllville
TN
Be nice to know what number was issued to the very first Scrambler and if it's still around.
Jk cj8
New member
Lahore
Pu
Hi I know I am posting to this forum a year to late but recently I was looking to buy a car and it had a number on the frame that was not the vin . I was wondering what it might be. I have a cj8 1986.
bdawgg
Member
Silver Member
Greenwood
MO
My frame stamp has a 'J' for the plant code...what/where is that? It is also different than the body in that 11th position...the 11th position on the body VIN is a 'T' (for Toledo I guess).
So, why the difference in the 11th position?
The frame sequence Nbr is the same as the body Nbr.
Craner8
Silver Member
Member
Orlando
FL
Not to hijack a thread, but jk CJ8 says his is a 1986 Scrambler. In Peru? Possibly one of the very few exported in 1986? That’s only the second one I have heard about.
ag4ever
Average Nut
BENEFACTOR
Silver Member
Richmond
TX
The frame stamp is not a full vin. I believe it is only Mfg, Engine, and serial no. No plant code or trans or even model.
