VIN locations?
Orionn
Vehicular Packrat
Ann Arbor/Ypsilanti
Mi
:confused:
Where is the OEM VIN number stamped on the frame or anywhere else?
My scrambler has no VIN plate, and has a state issued VIN and Body sticker.
(it was a re-assembled basket case with no title at some point)
I'd like to rectify that if possable
thanks
Vin
The only places there was a VIN when I tore mine down was a sticker on the body under the driver door, a riveted tag with VIN and other information under the wiring harness on the firewall and another riveted tag on the wiper motor cover. Nothing on the frame.
I rebuilt an '83 frame last year and found the VIN stamped on top of the frame rail on the passenger side hump above the rear axle.
Frame Vin
Jeff is right....... I just went and checked mine and it is barely legible, but it is JC and the last digits that match the VIN for the body.
"1975 to 1986 Jeep CJ VIN numbers are usually located in several possible locations. You should find a tin plate on the drivers side firewall near the brake master cylinder. You may also find one on the drivers side dash or the inside body panel by the floor near the parking brake lever. On mid 80's models it should also appear on the windshield wiper motor cover inside the Jeep. An abbreviated version is usually found on the top of the passenger side frame rail above the rear wheel."
There is/was also a tag on the firewall under the hood to the right of the steering column.
At this point I have completely stripped 3 Scramblers, 2 81's and an 83.
All 3 had a the dash VIN tage on the wiper motor cover.
Not one had anything stamped on the frame. 1 81 frame was pretty bad, so it is possible something was there and just rusted away, but the other 81 and especially the 83 were in pretty good shape and neither had any stmap on them.
None of the three tubs had any VIN markings at all.
None had a VIN sticker. 2 had a manufacturer sticker but it did not have a VIN on it.
SO basiclaly I am yet to see one with anything other than the dash VIN.
My 1982 has the vin on the passenger side frame, on a sticker just below the driver's door on the body, and of course, on the dash plate.
My CJ's have the vin number present on the firewall under the master cylinder, below the inside lip of the driver's door on a decal, the wiper motor cover dash plate, and stamped on the top of the passenger side frame rail above the rear tire.
The decal under the driver's door is most likely to not be present out of all the options (due to being removed, adhesive failing and it falling off, or painted/bed lined over) and the stamped vin number may be hard to see due to paint or rust but it should be there.
Sorry to resurrect a 20 year old thread...
I've got my Scrambler down to the frame now. Preparing to paint it.
I found this on the passenger side frame rail on the hump.
Does this mean my 1982 Scrambler was #5721 produced that year?
Should match final numbers in vintage (vin, not vintage. Darn auto correct) and means it was the 5721st jeep off line. I believe all keeps (jeep, darn it again) were counted in that. CJs, Wagoneer, J trucks, etc...
Be nice to know what number was issued to the very first Scrambler and if it's still around.
Hi I know I am posting to this forum a year to late but recently I was looking to buy a car and it had a number on the frame that was not the vin . I was wondering what it might be. I have a cj8 1986.
My frame stamp has a 'J' for the plant code...what/where is that? It is also different than the body in that 11th position...the 11th position on the body VIN is a 'T' (for Toledo I guess).
So, why the difference in the 11th position?
The frame sequence Nbr is the same as the body Nbr.
Not to hijack a thread, but jk CJ8 says his is a 1986 Scrambler. In Peru? Possibly one of the very few exported in 1986? That’s only the second one I have heard about.
The frame stamp is not a full vin. I believe it is only Mfg, Engine, and serial no. No plant code or trans or even model.
