What did you do with your Scrambler today? August 2014 version
did this yesterday. :) I love my Scrambler. :bacon:
Which Starbuck's were these pictures taken LOL:rotfl::thumbsup:
Looks good Mike:thumbsup:
I should have some "muddy tan Scrambler" pictures next week:fingerscrossed::wave:
Not a Starbucks. It was at a Tim Horton's.
When I got to this statement I felt myself breaking into a cold sweat and feeling a little nausea coming on.
;) no ER visit. As I broke two sockets getting the pinion nuts off, I was careful. Only used a 5' pipe on the breaker bar instead of an 8'. Did start to bend the joint in the breaker bar though. One ear curves slightly outward now.
So I've been trying to get my 84 Scrambler smogged here in CA the past week. Failed round 1 at the required 'Star Compliant' shop. :mad:
I have a rebuilt 258 with 6700 mi on the clock (rebuilt at Orange Engine in Anaheim - http://www.orange-engine.com/)
Howell TBI (CARB cert)
MSD ignition parts - 8207 coil, 8516 distributor, wires
Borla header w/ CARB sticker
It was all going good at smog... my emissions were passing (but just barely on the NOX and one other reading) until they checked the timing. My timing is currently around 0, and the 'legal' range is between 6-10 (ideally 8). Apparently when the timing is advanced my emissions are going to go up, and then the test will fail on that side. :mad: :banghead:
So, the catalytic converter becomes a focus point. It becomes clear that I have a 3-way cat, but it's a 49 state model, not the uber-cat apparently needed to satisfy CA (it was installed in CA, but apparently they changed the design in the last few years?).
So as of yesterday I now have a much larger Magnaflow 3-way cat installed. Next step is to get the timing adjusted and go back for another test (I don't know how to do that myself).
Driving around yesterday afternoon, I noticed that the jeep now hesitates occasionally under load in a manner it didn't do before (I did have some hesitation if I got into the throttle previously... I'm attributing that to the excessively retarded ignition?). So now I think I might have a back-pressure issue?
I'm pretty damn sure my Scrambler isn't a gross polluter, but here I am going through this ridiculous process to satisfy CA.
Any insight welcome as to what I should focus on next!
Thanks
Thanks
I'd try finding some land in a different state. As much as I hate Ohio's snow, at least I don't have to jump through so many doggone hoops.
Pulled a leaking steering box, waiting for replacement to arrive.
This week the trans is now in the white 85. Pretty much some clutch linkage and the skid plate away from a test run :thumbsup:
Well. I got the new radiator in. But to get the electric fans in I had to do some dremel magic. And now I still need longer bolts to get the fans mounted. So I am calling it a night. I will tackle the final install and the wiring tomorrow.
So I decided to put my new plates on.
It is a Dorman 620-104 for a contour. And it is new. I got the flex-a-lite controller for it as well. Need to figure out how to wire it up tomorrow.
I have that setup. Don't mount the controller to the fan shroud (as some of the install threads on the net have shown). It can melt the controller insulation? Worked great after I mounted on the fender.
Kk
Kk
I had not even thought to put it anywhere else other than the fender. Thanks.
The space is tight between the. Pulley and the fans, like my old mechanical fan was to the radiator (which caused this problem to start with). Hopefully I won't have issues with contact though.
found this on my Dana 60
also a chipped tooth on the ring gear, after further inspection the ring gear has lots of cracks
time to change to some 5:13's
Got the fan wiring done. I hope I don't have to do that again.
Washed the running postal one last time. That's going to be a sharp looking truck in the right hands. Checked the fluids, ran the engine for a while in hopes of emptying the gas tank; gas gauge is in the factory correct "empty" position at all times and the transport company wants less than 5 gallons fuel onboard. Put more air in the leaking tires. Got a new Sawzall blade for the postal tub. Wife helped me flip the spare top so urethane foam can be removed. The young guys who were going to help, well it's caribou season and two of them are headed to moose camp.
Lost overdrive in the tan Scrambler's 700R4:eek::banghead::shrug::confused::(
EDIT - might be a TC lock up issue:shrug:
I think it is time to open a shop with as many transmission as you go through.
I let a local shop rebuild this one, since its an automatic:thumbsup:
I guess I will have to see about the warranty:fingerscrossed:
It never got hot, doesn't have any water in the fluid, so :shrug:
Maybe the TV cable slipped, maybe stuck valve, maybe a servo is shot, I have no idea:shrug:
EDIT - maybe the torque convertor is not locking up. The 3-4 shift is pretty soft, I think you mainly feel the convertor locking up/RPM dropping.
I will plug in the scan tool, see if I have an error code. Could be the TCC switch, Top gear switch, or could be an engine sensor problem, i.e. TPS, temp sensor, etc.
I will check a few things myself, before condemning the transmission. All other shifts function fine, up and down, and reverse, runs normal temperature. Maybe the TC just isn't locking up anymore for some reason:shrug: The way this 700R4 is wired/controlled, the torque convertor only locks in 4th gear, IIRC:shrug:
