Changed all the fluids, greased everything up on the Red Scrambler, getting ready for Sicily Island ORV park in LA this weekend, then National's 1.5 weeks later![]()
teaching my boy to shoot his new Red Rider.
The more pics I see of your Jeep, the more I want to see.
Put 3 inches of lift on the rear today. Ran out of time. It took 3.5 hours to do the pass rear. Nothing was going right. A lot i cutting, drilling, pounding, etc. the driver rear only took 1.5. Some if it was learning curve but most was because things were cooperating.
Netted me only about 2 inches though. After I put the front lift on I will see what happens up there.
So I will be driving around with the rear up a little higher. Hopefully I will have time next weekend to finish the job.
The rear leafs I took off were crap. They fell apart as they came off and crumbled to bits. Left a ton of flakey crap all over my driveway. Darn am I tired though.
Here is the pic of work being done on the easy one.
I will post final pics after the front is done. But here is how it sits right now.
So, drove it back home
It has no 1,2,3,5 or Reverse left, but works fine in 4th. I have no doubt it is completely destroyed, judging by the sounds it made. At first, it kind of tried to catch on the other gears, but now, since I believe I finished breaking all the teeth off the counter gear, it is nice in quiet in the other gears
It worked very well in 4th, no noise or vibration, but I believe that is because in 4th, you are bypassing most of the gears, just locking the input/output shaft together.
So, I revved it to 3000 rpm, popped the clutch, finished breaking it.
Whats going on at Sicily island? Am I missing something.
, but our local Jeep club had a ride/camping trip out there this weekendSorry to hear Raymond.
Aren't you glad you got your "Bad" trip out of the way now. All good from here on out!![]()
The bad thing, I am out of "spare T5's" now
Raymond... when he breaks, he makes sure he finishes the job...
(I want to see the internals when you pull it apart!!)
Which Lift did you go with?
For only 3" (I assume it was really a 2.5?) did it just keep the stock pitman arm?
I am considering this vs. just replacing the rear "super shackles" on mine (with 1.5" lift springs and normal length shackles). I figure it would add almost exactly an inch over the current setup. Not sure it's worth the price for 1".
KK
Not today, but Friday afternoon:
Had the T5 in my red Scrambler self destruct at 75 mph, about 160 miles from home.
Got to the side of the road, put it in 1st gear, stalled the motor. So, I revved it to 3000 rpm, popped the clutch, finished breaking it. But, by doing so, I got it to work in 4th gear ONLY. So, drove it back home. It has no 1,2,3,5 or Reverse left, but works fine in 4th. I have no doubt it is completely destroyed, judging by the sounds it made. At first, it kind of tried to catch on the other gears, but now, since I believe I finished breaking all the teeth off the counter gear, it is nice in quiet in the other gears. It worked very well in 4th, no noise or vibration, but I believe that is because in 4th, you are bypassing most of the gears, just locking the input/output shaft together.
I need to rebuild the spare T5 in my garage this week, get it swapped in, if I am going to make the National trip next week in it
After blowing up red Scrambler, I got my TJ Rubicon and drove it to the Jeep ride. And of course, a stick popped up and broke the front diff lock compressor in 1/2 first thing Saturday morning.
And on Sunday, while driving home, engine bucked hard, check engine light came on. Coasted to the side of the road, engine still running, wont rev past 2300 RPM. Cam position sensor went out, but I limped it home about 75 miles at 55mph.
Just wasn't my weekend![]()
