Pulled speedometer clip, cover and gear. De-gunked and replaced o-ring (hopefully preventing re-gunking). Replaced with correct 32 tooth gear. Matches GPS almost perfect from 40-65 MPH
Still pretty laggy and wrong below 30. May have to work on cable routing. New NAPA cable, new OMIX speedometer. Not that speeds below 30 matter anyway. Mostly wanted new odometer to be fairly accurate
(since it is currently my gas gauge)
Making steady progress. Speedo works - check! Temp gauge works-check! Fuel gauge works - check! Oil pressure gauge works - check! Speedo actually reads accurate - check!
Need to drop tank and check sending unit. Replace when body was off, and worked for a bit, but the resistance no longer changes.
