What's on your Work Bench?
jc_chandler
Active member
Denver
You might try a curved diamond needle and some strong thread and stitch the vinyl together over the zipper. You probably won't need to remove it until it's worn out anyway.
I like that idea, will give it a shot. It's not like anyone will really ever see the stitching anyway.
That looks great! What are the buttons for inside the console?
The buttons are for a code to open the lock box. But the large button at the rear is a biometric fingerprint sensor. It really works great. It also had a phone ap but the software wanted too much info off my phone, so I removed the Wi-Fi module.
There were a couple of mechanical security issues that I found online so I fixed those too before installing.
I’m really impressed with it- it has a 10ga lid. The sides are even thicker. Online they shot it with a 9mm several times and just dents. Even ran over it with a car- no problem. It weighs almost 18lbs…
Kim Dawson
Molalla
Or
Working on the pattern for the front frame cover. It's got to be at least 1/4" thick . . . it will be a little thicker. I added to the bottom side and on the top. The driver side "L" has to be thick enough to recess into to clear the steering bolts that stick up from the frame cross member. I'll make the recess for the left hand drive. Anyone with a right hand drive can recess that side. I put in an hour or so every few days. Eventually I'll get it ready. After seeing what people are asking for old ones, I almost didn't sacrifice this one. But when I'm done, I'd rather have a new aluminum one that will last forever than the old cracked one.
jc_chandler
Active member
Denver
Very cool, please add me to this list
Chamba
Not obsessed: focused.
Vero Beach
Had a tree branch fall on our camper trailer. Replacing the awning (it's on backorder, looks like another 6 weeks until I get it (I sure hope our illustrious leader calls our transportation secretary back from maternity leave soon so he can solve these issues) and a broken sky light causing a good leak. I decided to replace both skylights since I'm up there.
Not Jeep related, but now it's off my work bench to-do list. Not purdy, but should hold up. Luckily it's 12' up and out of sight.
HighSierra CJ
Scrambler Enthusiast
Ducor
Ca
Never fear, I believe once our transportation secretary is back on the job, all problems will be solved😳
Kim Dawson
Molalla
Or
More body filer, primer, and putty. It'll take awhile until I get it smooth enough, but I'm working on it.
