Here's a good example:
http://cgi.ebay.com/ebaymotors/Jeep...2408338?pt=US_Cars_Trucks&hash=item3371ca3112
The price is way too high for what you are getting and the diamond plate and over-use of liner just makes this Jeep even more incorrect. I mean, slapping that diamond plate on makes this look cheap and likely covers up flaws in the work done. Dunno, but this is a rebuild and not a restoration . . . .
I posted this here because I continually see the mis-use of terms such as restoration, "upgrades" and so on. Superseats are not an upgrade nor is a Weber for example. A good running Carter will do just fine (if you can find one of course). I would consider the one-piece axles an upgrade but anything else is normally just a modification from original.
Examples of things which aren't upgrades but rather mods include:
liner material
carbs
different diffs
engine swaps
wheels
tires
winches (the original 8274 or Ramsey were great winches)
I would consider the following to be upgrades but deviation from original:
fuel injection
HEI ignition
Chevy heater blower (larger and more volume)
1 piece rear axles for the Dana 20
Dana 44 rear end swap (original Jeep equipment)
The reason I write this is more and more many people are finding original Jeeps and highly modifying them and believing they are adding value and making them worth more. Negative! The buyers who would pay $26K for a Scram want original stuff on it--and they don't want Line-X, diamond plate, incorrect decals, chrome dash bezel, cheapo dash pads and aftermarket steering wheels.
When considering a restoration consult the folks here/elsewhere and find the right parts. Scramblers and other CJs were quite capable off road in stock form, the seats when new were VERY comfortable (so should be rebuilt and recovered if possible), and so on.
For the not-so-informed I feel these ads are deceiving and Jeeps like this avoided if you are looking for an original . . . .
Just one person's opinion but if you want to get bucks out of your Scram resto don't follow this sellers lead . . . he'll likely sit on this for a while at this price. It's a nice Jeep but not $26K nice . . .
liner material
carbs
different diffs
engine swaps
wheels
tires
fuel injection
HEI ignition
