Wiring harnesses
My guess would be close enough. I believe 1983 was the first year for the wiper delay wiring. I'd use it. Maybe some of the more knowledgeable guys on here can confirm this.
I haven't encountered any significant differences (or changes) between 1983-1986 wiring harnesses. There may be some changes in the engine harness depending on 4 v. 6 cyl, but everything else should be interchangeable.
And from my experience, Kim is correct- the 82 harness I have had a different wiper switch/connector than the 83 (two wires to the switch in 82 as opposed to a round plug with 4 wires if I recall correctly).
Alright thanks guys, trying to save myself a bunch of money. Painless wants $800+ for an 85' scrambler harness. I can get a 83' cj7 harness for about half the price.
Painless would be new wire the salvaged ‘83 would be almost 40 year old wire.
Is it me or does it seem like all old CJ wiring is black when you strip wire off of it?
Do the new wiring harness kits come with all the wire ends/plugs that fit like the original harness does? Is the $800 painless harness all made up with all the ends ready to go? I've always found a good original harness and cleaned all the contact points well. All new would be nice though.
Barrys your correct. I'm guessing it's oxidation. Try soldering it to new wire. Without flux it doesn't get a good bond (cold solder joint). One of the reasons I go with a new wiring harness vs reusing old harness (not to mention where old wire connects to plugs). If you are doing a original restore I can see reusing the harness. Kim I read somewhere where someone got one of the wire kits without connectors. It cost a small fortune to fine and purchase all the connectors.
I had the starter trigger wire ground to a battery + feed inside the stock wire loom (unaltered wires, never opened the loom in that section) WHILE DRIVING. That was fun.
After that, I stripped all of the wire loom/tape off under the hood to inspect the wires and I have never trusted the old stock wiring again.
Just my 2 cents here, obviously YMMV. My scrambler came with an improperly installed painless harness (the PO was not particularly adept, electrically speaking), which created more hassle than it was worth in tracking down the many issues. As such, I opted to remove the whole thing and will reinstall an OEM harness that has been unwrapped, inspected, and tested with a DVM. Although I definitely agree that old wiring can have 'PO' hack issues, mouse damage, etc., I routinely use sections of oem harness wire (correct color/gauge) to splice in and make repairs. In my opinion, the quality of the copper (if not oxidized and insulation is in good condition) is higher than the corresponding gauge wire available now days, especially with the offshore producers. Plus, keeping the colors consistent makes for less headscratching when tracing, troubleshooting and reconnecting circuits using the FSM wiring schematics.
Personally, I wouldn't have reservations about using an OEM harness that's been thoroughly gone through, JMHO.
I think this is a key point. Only issue is finding an OEM harness that has been checkEd out as good before spending the cash. With a painless, you know they are all good. Now, I have never touched a painless harness so I can’t comment on if they are better than OEM, as good as OEM, or worse.
Are wiring harnesses from a 1983 cj7 the same as a 1985 cj7?
Yes,
Many months ago I called Painless and was told that there is plenty of wire with the 10106 to do what needs to be done for the CJ8. He also mentioned Painless bought the mold and has the rights to the original jeep CJ fuse block and engine compartment connector. He then went into telling me all about the 10150 and how it would save me time and money :sleep:. If I was doing a complete teardown that's the one I would go with. I opted to rebuild my OEM just to get me up and running, I will be adding a second fuse panel in the future for whatever accessories I do.
Download the manuls they came in handy when rewiring or troubleshooting a problem.
Jeep CJ (1976-1986) P/N 10110
1975 & Later Jeep CJ Harness P/N 10106
Jeep CJ Harness P/N 10150
Yes,
Thank you
I wired a CJ6 with Painless late model CJ harness and had a pile of wire I trimed.
