model kit
Your fit and finish is MUCH better than the one I built a few years ago, ( I have it around here some where, its probably broken in a box, If I find them I'll post up my build in what ever sad state they are in. I started mine with a Revell and monogram CJ7s (same kit), built the rear of the body with evergreen plastic. The motor a 4.0 from a wrangler kit, replaced the buick V6 the cj7 kit came with It would be relatively easy to back date the 4.0 to a 4.2 engine by adding the carb from the Cj motor and a little file work. Spark plug wires are dental floss dipped in glue for the boots then dipped n paint and left to dry before attaching them. Radiator hoses were stretched sprue The high back bucket seats, mirrors and taillights also came out of a Tamyia YJ wrangler. The Tamiya kit is much higher quality in the detail parts.
My BFG MT came off a 1/20 scale Lindberg Baja racer GMC Sonoma pick up kit number 72505, the only parts of that kit I used. They scale out to 36" in 1/24 scale If you do this you will need to make new springs, the red model used layered ever green to make of the spring packs the blue model used brass and soldered together. You will also have to putty up the recesses in the axle molding as they will be visible. if you lift your model. I used stretched sprue for brake lines and evergreen tube and kit parts for the exhaust.
The BFG AT came off a 1/20 scale police chevy blazer kit form about 1980, They were slit left right plastic moldings that were almost impossible to make look right. regardless they are another choice if you plan on lifting your kit and can find the donor kits.
If you need anything let me know. Going to go find my model now.
Edit found them all busted up. I wish I had photos of them done and complete. These where made maybe 10 years ago well before I started resin casting or airbrushing. Even so I was pretty pleased with some of the scratch built parts like the seat belts (scale 3" wide fabric medical tape with paper clip buckle and leave springs.
That said your master looks much better than my attempts so I will be interested in a couple to fix up these basket case wrecks. The blue body turned out a little better than the red one. I never did quite get the rear fender flares sculpted right from squadron putty. Sorry for the shaky pictures my good camera does not have a charge on it.
