1985 cj8 build
That stack case is a nice unit. I was seriously considering that route myself, but I found I was able to get a low mile Rubicon case for less.
well Ups dropped of some stuff today. I had ordered the stuff I need to bolt this 5.3L engine into my frame. I bought an adapter plate that changes the new style 5.3L engine to the old style 3 bolt sbc from street& performance. They have a really cool website. The catelog is kind of hard to find stuff. But man could I spend some money there. you can find the motor mount adapter plates on page 102. click on the link below for the catelog
http://www.hotrodlane.cc/2010 PDF CATALOG/catalog2010main.html
And I also order some M.o.r.e. sbc to jeep cj motor mounts.
http://www.mountainoffroad.com/Catalog/BombProof MM/jeep-cj-motor-mounts.html
Next I need to figure out still what I am going to due about a front drive shaft and a transfercase. I really want to put the motor in with the trans. to see how it looks. but I know I'll just be making more work for myself. anyhow
In with the new......
Well it has been sometime since I posted last.
I finally got my novak adpater(4l60e-dana300).
And today:
-I seperated the motor and trans.
-loaded into my truck
-took it to a local tranny shop(Northern Ohio Automotive Transmission)
-brought it home
Keith at the trans shop: went through my trans, replaced the tail
output shaft, updated my servo to corvette. Everything turned out
real nice. Now I have to clean up my dana 300 and bolt it on. and
then drop the motor, trans, transfercase in. Here's some pic's
Novak's kit:
Transmission removed from motor:
Transmission with adapter
Close ups of the adapter on the trans:
Left over OEM parts:
more pic's to come. The weather is finally get nice here In
NE OHIO. But I am guessing that we will get a few more
weeks of cold, rain and snow.LOL
7jeeps7kings
Interesting- they moved the speed sensor port to the side from the top. Did they include a locknut for the speed sensor? Mine was without the locknut and I fabricated a locknut because I didn't trust just the sealant. I sent Eric at Novak pictures of my modification, and he said they were looking into supplying a locknut.
Looks good so far!
Looks good.
Do you have any pics or info on your trans./transfr. crossmember you would be willing to share?
thanks.
Looks good so far!
I'll have to check if there is a locknut?
Looks good.
thanks.
trans is a 4l60e out of a 2008 sierra 1/2ton. transfercase for now is the stock dana 300 that came in 1985 cj8.
I am planning on running the stock oem skidplate as well. i want it to look as stock as possible from the exterior.
the only thing I might do different is go with a stak's dana 300 flip housing. but that all depends on the front
driveshaft clearace to the trans pan.
thanks,
7jeeps7kings
Well as stated above here are the pictures you have
been looking for If you are planning on or are in the
middle of adapting a dana 300 transfercase to a 4l60e
transmission. As I have been building this cj8 I have
looked for pic's of the clearance issue of the front
driveshaft with this combo. well I did not have much
luck finding the ones I was looking for. But now that
I have the adapter and a camera here you go.
I'll start off with this picture:
You can see that there is 4 holes in the adapter
for every bolt to clock this transfercase. I am going
to name the clocking holes 1, 2, 3, 4. 1 being the
more or most counterclockwise hole then 4. and 4
being more clockwise hole then 1. and the rest fall
between the two. I hope this makes sense?
starting with the 1 hole. This puts the transfercase
almost flat. this also gives you clearance to spin the
driveshaft without hitting anything. this also places the
transfercase and driveshaft u-jont above the transmission
pan and housing. I called novak and they stated that this
would not be a good choice. They stated that when the
front axle drops when flexing it might cause the driveshaft
to flex down and hit the transmission causing damage.
Rear view (almost flat)
Top view (you can see the clearance)
Side view ( you can see that its above the tranmission housing and pan)
Then the 2 hole. This hole give the transfercase
alittle more rotation downward. but you are unable
to get the driveshaft u-joint into the front output
yoke due to clearance issues So don't even try this hole.
Rear view
Top view
Side view ( you can get the drive shaft in
if you rotate the front output yoke and slide
the u-joint in. but it would be in an angle towards
the passengerside front tire.)
The 3 hole. Even more downward rotation.
You can put the driveshaft in and spin it.
but it hits the transmission pan. And the
front output shaft on the transfercase and
the front driveshaft yoke are below the
transmission housing and next to the pan.
You could have your transmission pan modified
for clearance. Novaks strongly recommends this hole.
Rear view (almost sits like stock)
Top View
Sideview (you can see how this set the front
drive shaft below the trasmission housing and next
to the transmission pan.you can see this is the last
hole you can use. The shift rails are almost
touching the transmission housing)
And lastly the 4 hole. Which you can't
even use. Because the shift rails would
hit the housing. no pictures other then
the one above (sideview#2)which shows
the problem.
I hope this helps. Also this is not including any problems you may or may not have with your skid plate, shifter, body clearance...
Drivers side drop makes all those problems disappear.
I will be go with a staks housing.The problem is.
I will be on the hunt for a new front axle and have
to come up with the extra money for the staks and
front axle! I think for now I'll clean up my dana 300
bolt it in place and run rear driveshaft only till I come
up with the money. I was already prepaired for this. I
was hoping it wasn't going to be this close. But thats
just another day and the life of modifying stuff!
7jeeps7kings
Moved this thread to the complete builds forum :thumbsup: never noticed it was in the drivetrain forum before
Sorry. I know it's a complete cj8 build up. I just figured I would start there since I was working on and asking questions mostly on the drivetrain. Well atleast for now. LOL.
thanks,
7jeeps7kings
well it's between the frame rails.
Well it's between the frame rails. But it didn't go without a fight.
Problems:
-One man operations with a cherry picker.
-A chain.
-And trying to take everything in one trip.
But I won. Yeah. O and I bought a load lever. So you can say I cheated.
And it fits like it came that way from the factory.
Other then the fact that I had to cut the pinion axle bracket on the frame.
And I'm going to have to get creative with my hand grinder to get the ac unit back
onto the motor. the new motor mounts and the ac bracket hit.
7jeeps7kings
Congrats! I remember the feeling of accomplishment getting the new motor in and mounted :thumbsup: I have to say that those are good looking motors.
On the thread move, it was everything about the frame and all back at the beginning that had me thinking you were going through the whole build. If you want me to move it back, no problem!
thanks! I wish it was in for good. Unfortunately it's only in for mock up purposes! So I will have to pull it back out for paint and such.
No big deal on the thread move. Just explaining myself.LOL
thanks again,
7jeeps7kings(Drew)
summer of jeepen
well work on the cj8 has been slow. I am still in the process of figuring out
if I should go driverside drop transfer case/ front axle or buy an atlas and get 1" of clearance on the passenger side of the trans pan. I am wondering if anyone out there in jeep land has any pic's of a atlas transfercase bolted to a 4l60e passenger side drop? One way or the other I have to spend money. I just want to make sure it's the right step. The only new progress I have made on the cj8 is I have the body mounting kit from daystar to be put on and I have a set of 33" bfg mt's under her right now.
On the other hand I have been busy with the big yellow cj7. I took the 3" body lift off(which made a huge difference), I've added an overflow bottle from the radiator, I am waiting on a stainless steel dash, and I have big daddy offroad rocksliders sitting in my garage just waiting to be bolted on. and some other things here and there for the cj7! I don't have time for pic's but I will update here soon. this has been another busy summer! :beerchug:
keep jeepen,
7jeeps7kings
Well someone is out on the trail! and it's not me!LOL
My buddy just got back from Penn's woods(jeep jambo). here is a pic of him and his son.
it can also be seen on: http://online.jpfreek.com/ he said he was the only willys
jeep and there were only a hand full of late model cj's and all the rest were jk rubicons!
Are you still looking for 15x10 wheels? If so I have some, just not sure what the shipping would cost from Central Texas to Ohio.
Bo
Bo
Pm Sent. I am looking fo 15x10" wheels with 5x5.5" bolt pattern. But not just any kind. I am looking for the mickey
Thompson challenger wheels that look like the old cj factory slotted mag rims. thanks for the reply.
fiberglass body?
Well I started to place my body mounts in the frame and noticed that there is a huge gap
between the second to last body mount (towards the rear of the frame) and the frame.I
know on the steel tube there is a support channel that is like 5"-8" inches tall that is mounted
to the tub and spreads the width of the steel jeep tub. And with that support bracket there
is no gap. I am wondering what any of you have done with your jeeps that you replaced the
steel body for fiberglass(pic's please). It's only two of the mounts. But I hate to have
two 5-8" mounts and the rest 1".
thanks,
7jeeps7kings
