Well as stated above here are the pictures you have
been looking for If you are planning on or are in the
middle of adapting a dana 300 transfercase to a 4l60e
transmission. As I have been building this cj8 I have
looked for pic's of the clearance issue of the front
driveshaft with this combo. well I did not have much
luck finding the ones I was looking for. But now that
I have the adapter and a camera here you go.
I'll start off with this picture:
You can see that there is 4 holes in the adapter
for every bolt to clock this transfercase. I am going
to name the clocking holes 1, 2, 3, 4. 1 being the
more or most counterclockwise hole then 4. and 4
being more clockwise hole then 1. and the rest fall
between the two. I hope this makes sense?
starting with the
1 hole. This puts the transfercase
almost flat. this also gives you clearance to spin the
driveshaft without hitting anything. this also places the
transfercase and driveshaft u-jont above the transmission
pan and housing. I called novak and they stated that this
would not be a good choice. They stated that when the
front axle drops when flexing it might cause the driveshaft
to flex down and hit the transmission causing damage.
Rear view (almost flat)
Top view (you can see the clearance)
Side view ( you can see that its above the tranmission housing and pan)
Then the
2 hole. This hole give the transfercase
alittle more rotation downward. but you are unable
to get the driveshaft u-joint into the front output
yoke due to clearance issues So don't even try this hole.
Rear view
Top view
Side view ( you can get the drive shaft in
if you rotate the front output yoke and slide
the u-joint in. but it would be in an angle towards
the passengerside front tire.)
The
3 hole. Even more downward rotation.
You can put the driveshaft in and spin it.
but it hits the transmission pan. And the
front output shaft on the transfercase and
the front driveshaft yoke are below the
transmission housing and next to the pan.
You could have your transmission pan modified
for clearance. Novaks strongly recommends this hole.
Rear view (almost sits like stock)
Top View
Sideview (you can see how this set the front
drive shaft below the trasmission housing and next
to the transmission pan.you can see this is the last
hole you can use. The shift rails are almost
touching the transmission housing)
And lastly the
4 hole. Which you can't
even use. Because the shift rails would
hit the housing. no pictures other then
the one above (sideview#2)which shows
the problem.
I hope this helps. Also this is not including any problems you may or may not have with your skid plate, shifter, body clearance...
