Need a little prayer
So this was where things for me went south and the first time I got rather upset over the prodject. As I was working at the cowl area I took my blow gun and started blowing the crap that was down in the cowl and thats when I saw a bunch of rusted metal chucks. So I got under the dash and pulled the heater box out.
And thats where I got upset. Those who are familure with this body style know what I mean.
The rise(I have heard it refered to as a hat) that keeps the water from running into the heater case was gone. I took a close look at the cowl body itself under the dash and that seems pretty solid and no small rust holes. At this point I looked over at the passenger fresh air vent and noticed there was sealer up around it and the hat looked like it was new(or done before my dad got the car). Thats when I got the idea to made a new one and just glue it in like the drivers side.
So I called my dad and told him what I had found(upset of course over it) and just talking to him helped me calm down. We both came to the conclusion that we are sticking to the plan of trying to get it done and not doing a full restore. At this time I told him of my plan to make a new one and he was pretty thilled at this. So I got off the phone and started reading on the net. Thats when I found they have replacement hats(ventr repair kits) and just had to tell him about it--he again was thrilled.
So I am back in the game and moving forward.
So when I got the heater box out I noticed alot of just rust(not deep) all over and looked like most of it came from the seam that I had worked on in the engine bay. So I got on my back with wire wheel in hand and made allot of brown clouds. So now its ready to also be sealed when I do the floor.
One of the pressed in hinge mounts had pulled thru for the hood. So I had to rework the metal to where the insert was back into place. A couple others had also spun so I decided to go ahead and tack all of them in.
Here is the worse part of the engine bay---the battery tray and the fenderwell around where it sits.
So tonight I got all the rusted areas wire wheeled and then rust killer on those areas. At that point I went and scrubbed down the whole engine bay and washed it down--last big step before ready to paint.
And here is the bad spot. I took and removed all of the ruff edges and then hit it hard with rust killer. The new battery tray will help give it the support it needs.
Ok still working thru things. I got the engine bay all whiped down and prepped and masked off. I didn't make accordinly to the factory lines of the engine bay but was pretty close. I also chose to remove the hood latch assembly and paint the front of the core support. I figured it would look cleaner once the car in painted and the new front items are installed.
I was going thru items that wse have removed to date and figured since I am getting closer it was time to get the hood hinges ready. We got new ones without springs.
Now I was figuring these would be a complete bear to remove off the old ones and put onto the new ones and figured I would need to make a tool to aid in it. Well I sat back and an idea popped into my head and it turned out to be a golden idea.
So what I did was use a punch firmly placed in the vice. I took the hinge and slid the one side of the hingle/spring down over the punch to grab the one side of the spring. I took a rachet strap from the post in my shop and to the other side of the spring and racheted it down.
It worked like a champ. To release the pressure on the spring I just released the rachet strap while holding the free length of strap to calm the recoil.
Cleaned the springs and did the same thing to install the springs on the new hinges.
And I thought I was going to beat myself up doing them..
I did one light coat on the seam area at the cowl and then sealed the seam up. In the areas with bad rust that I killed (battery area and above the steering column) I did multiple coats over a period of a number of hours. But I just got done doing a final coat on the whole thing. Don has the cross supports and shock towers and he is going to sand blast them and I will get them painted tommorow night. But I am not totaly happy with how it turned out but I was expecting that due to not totaly stripping the whole area. But it does look a TON better.
Ok put another good amount of time into it. I figured since I had the heater box sitting there I needed to get it done up.
Both the doors inside the case were stuck in place and the frest air door at the passengers foot was also stuck in place.
So I tore it apart.
I cleaned the heater core and flushed it out.
Man it was a mess inside. Granted not all of it was from the heater assembly itself but it was pretty rusty inside.
So it took some work and PB blaster. I had to have allot of patience to finally free up the stuck doors but I was able to do so. All the metal parts got coated with naval jelly to help kill the rust then all metal parts inside got painted to help keep anything from flaking off.
I fully assembled the case and chose to just paint the whole assembly. The composit part of the case had rust stains in it and I felt it would look better all one color.
Just a little update on my dad.
The 3rd round of chemo took a little more of a toll on him than the prior 2.
His spirits are still VERY strong but you can tell it has taken its toll on him.
This morning he went in for another MRI to see how the treatments are doing.
He goes in again tommorow to go over the results and see how effective the chemo is. At that point I am not sure what the next measure is.
Today was a good day. My dad came to my son's JV football game and then came over to see his car and drop off some more items for it. He is just TICKLED PINK in how its looking... You can tell he is EXTREEMLY excited and my mom pulled me aside and again said thank you for the hard work and it has done exactly what I wanted it to do for his spirits.
That is a great thing that you are doing for him. It is something that everyone should strive to do. Your dad did a good job on you boys.
The Mustang is coming along nicely. Should me him feel really good to go out in it and drive around.
Carl
Well I just got off the with my dad as he was leaving his doctors apointment and these are his exact words Cancer lesions in the liver have gotten small so we're on the right track. I feel like dancing.... Yahooooooooo
So we are on the right track and we know progress in the right direction is being made--he's going to kill it!!!!!!
Right on, Crash! That's great news!
Great News......
Killing Cancer in the Old Man and the Car.....
Honestly, it is good to hear that you might be on the right track.
Carl
Thanks guys--I am pretty excited by the latest results. My dad started his next chemo treatment yesterday...
Don got the parts I needed blasted so I prepped them and threw some paint down.
I got the cross supports installed and sealed at the pinch seam
I got the shock towers installed with new bolts(old ones dead) and got the shocks installed allong with a couple items in the engine bay.
I think it turned out pretty decent..
At this point I don't want to do anything more in the engine bay till I can have a few days for the paint to harden. The paint for the interior showed up at my dads and will have it tonight so in the mean time I went back to the passenger seat adjusters.
As you can see they are in poor shape. One stud is broken and 2 others are bent--odd and they barely move.
This is where I learned a few things. The studs are pressed into place on the rail (square hole). So I started by cutting the stuff flush with the square portion of the stud.
Once cut I ground the square area down to very near the rail and then pounded them out--pretty simple really.
Now both stud tops act as stoppers so once those are removed you can move the slider beyond its limit and seperate it. There are 2 roller balls and 4 nylon sliders.
I cleaned the rails of the sticky goo from many years and polished the areas where the balls ride. I greased the ball areas and reassembled the slider assembly. At this point I use long bolts and tack welded them to the slider and wala they are in great shape again.
And painted up and ready
So I have been doing one thing for the last 2 days on the car.
I did some research and asked around and ended up deciding to go with an Eastwood product "Rust encapsulator" and had my dad order a gallon of the stuff. So it finally arrived and I was ready and waiting. So for the last 2 nights I spent painting the floor from front/rear with 2 coats and I went up the firewall under the dash to the cowl/firewall seam and farther under that where I could get the paint. So now that my brain is shot from fumes(lol) I sit here eating crayons(jusy kidding). But I am pretty happy with how it turned out. Also I knew of 2 tiny pinholes but found a couple more thanks to the paint and got those areas sealed up nicely/protected.
That is way cool news crash. We will continue to pray that this direction in your dad's healing journey continues :thumbsup:
Thanks for letting us join you in this journey...
z
