- Biloxi
- MS
And a pic of the cover bolted up. I just bolted on the front end temporarily. I will have to remove it again to install the shifter cable, which I haven't ordered yet.
Pic of the side fill plug.
Pic of the shifter cable hole.
Stuck the stickers on the covers. I thought the yellow Ox stickers would look good with the yellow and orange decals that I plan on sticking on the red body.
Pic of the rear end, 4.10 gears and Ox locker.
Pic of the rear cover internal shifter. Notice on the cover how below the area with the mounting holes just has a series of indentations instead of a continuous flange.
Pic of the old cover. Notice how the area below the gasket is a continuous flange. I hope the new cover doesn't leak. I normally glue the gasket to the cover so that I can remove the cover without buying a new gasket, but with the Ox cover i glued the gasket to the axle housing.
Pic of rear cover temporarily mounted up.
Two quick frame overview shots, that's it for now.
