Need some HELP w/ TBI!
SCJeeper
Pickens
SC
Hey Everybody! I haven't been on in a few weeks due to the new addtion to the family. He was born on 2-9-11 at 2:23 PM. Mom and Baby are doing great! Back on subject....back in January I was messing around in the field at my house crawling up some hills and just over all messing around in 4 wheel drive and noticed that when anytime the Jeep would be a really low RPM like when crawling up a hill with no pedal mashed....it would idle itself up I guess to keep from choking down. Before I go any further let me state the that PO had installed a TBI setup from a 4.3 motor on my jeep. It has been really nice to tell the truth at least to this point. Soooo......from that point on I seemed to start having problems with it running really rich until it got to the point that when you cranked it would flood itself out. Not realizing this I....not really being a mechanic by anymeans.....changed the oil, plugs and wires and air cleaner, fixed a couple of old hoses that were creating vaccum leaks...all stuff that needed to be done anyway...still didn't fix the problem although I do think that the flooding had fouled a couple of plugs. So the jeep was still flooding itself out at low RPM's and I was clueless. I had nothing to lose so I just started taking the TBI apart. At this point my dad was handing me tools and whatnot so I asked him to try to crank it while i watched the injectors to see what happened. Just to make sure that the injectors were not stuck open I unplugged the power to them and then he turned the key. No gas coming from the injectors but the motor still cranked and ran smooth until it burned all that had been dumped in it previously. So now I know that the injectors are not stuck open so I plugged one of them back in and he cranked it. Ran like a champ with the one injector dumping fuel in the TBI it was just running at a really high RPM. I don't have a tack but I'm guessing 1500-1800 RPM's. Great throttle response too. I plugged the other one up and back to falling all over itself trying to flood. Unplug it and back to screaming and running smooth as silk just at a really high idle. Any ideas of what would be causing the injectors to be dumping so much fuel in? It really runs and drives great on the one injector just idles really high at stop signs and stuff but I know that I have not fixed the problem.
Thanks for the help and sorry for the long read just figured that you would need the back story.
Brett
Has it set any trouble codes? Hopefully the PO installed the check engine light and OBD diag connector.
Sounds like it thinks it's running lean, so it's dumping fuel. Bad O2 sensor? Thermostat stuck open so it thinks it needs to do a cold enrichment? I'm no expert, but those are a couple initial thoughts.
no cades at all and yes he was good enough that he installed a Check Engine light and diagnostic port. I have thought about a sensor being messed up but had not thought about the thermostat. I also had the thought of too much pressure from the fuel pump.
Check your fuel return line to the tank. Try to blow compressed air through it, if you can. If that return line is stopped up, all of the fuel is forced through the TB.
I have not worked the bugs out of my junkyard TBI yet, but this was exactly the same problem I encountered upon initial install. My problem was that the Chevy computer code caused the system to dump way more fuel upon cold startup than the Jeep could take and would flood the engine every time. My solution was that I had to read the PROM, adjust the cold start fuel map code, and burn a new EEPROM with adjusted parameters. I had to tweak it a few times until it was right.
I am pretty sure that isn't what you wanted to hear...
If you have the Howell system, it is probably a different matter since they presumably have worked this issue out. I, however, was initially using the stock S10 computer code.
How complicated would it be just to throw a carb back on it. I am not opposed to that idea at all just didn't know what would happen unplugging all the wiring and everything that has to do with the TBI and computer.
Tbi
Couple of things to check as mentioned above 1st replace the O2 sensor mine was doing the same thing and the O2 sensor had went bad, 2nd as stated above check the thermostat or even better replace it with something around the 200 degree range TBI's like a warm motor. 3rd double check for a vaccum leak. 4th thing to look at is the voltage to the computer and at the battery TBI's need voltage if your voltage is droping out or have low volts to the computer it can cause all kinds of crazy things, a bad cell or a week one or even just dirty or corision at the connectors will make the computer go nuts. Hope some of this helps don't give up on the TBI it's a great system when it works right......lol:fingerscrossed:
it probably would not be a bad idea to replacet he 02 sensor anyway just for poos and hahas. Thermostat would be an easy swap since it is probably the original anyway. Battery is less than a month old and cables are new too. At least i don't feel bad throwing parts on this thing because they need to be replaced anyway right!
Tbi
make sure and take your old O2 sensor with you if you can get it out they can be a bear to get out and make sure and put anitsieze on the new one, mine eats O2 sensors. Think do to it just being a trail rig and not driven or started for long periods at a time ( hope to change that this year lol) If it hasn't been changed in awhile that maybe your issue. Check the connection on the back of the computer depending on where it's mounted it could have issues with moisture corroiding the contacts it's an easy clean up if it has any green in it at all clean it really well. the next thing would to look at your grounds a loose ground can cause issues with low voltage to the computer, i've had trouble with the ground strap from the motor to the frame working loose a few times. Good luck and let us know what you find.:shrug:
I know that the stock CJ alternators did not put out enough voltage at idle, so replacing it with a later model (similar to the year of your TBI) or even one of the newer CIS units can solve idle problems.
Stock alternators i think are around 28 to 30 amps i replaced mine with one for an 83 or 84 3/4 ton chevy camper speacial it was a direct bolt on and even clocked right for the cj plug it puts out around 85 amps big differance.:woot:
check map sensor vacum and check voltage from temp sensor. Have seen alot of temp sensors fail. Should be a two wire with black and yellow wires.
Good call on that had forgot about map sensor correct me mike if i'm wrong but the map sensor needs to also be mounted higher than the TBI
There is a program called winALDL (free) that can interface with the TBI computer. You will know in an instant which sensors are (if any at all) bad. You do need to buy/make the interface cable, but the schematics are online somewhere. Without this, I would have NEVER gotten my system to work since there was a bad sensor and a vacuum leak initially.
Here is the site: http://winaldl.joby.se/
Dang guys all this information is great. I checked all my grounds last night and they are all good. There are two things mentioned above that I am a little suspicious of. One being the 02 sensor and the reason being I think that I could have been the one that messed it up....here me out....during the Christmas parade of course everyone was revving up their big V8's and making alot of racket so me not going to be outdone started revving the almighty I6....I think its got a nice growl to it! Could me doing this have messed up the 02 sensor? I am not kidding that all this trouble started after that, maybe coincidence but maybe not? Second is the alternator....the Jeep kept being dead on me and I assumed it being a combination of the really cold winter that we have had and me not knowing how old the battery was....so I put a new battery in it. Welllllllll........the new battery has already died but I really just assumed that it was due to trying to crank and crank and crank until it just sucked the juice out of it. Now that someone above talked about hte alternator not putting our enough voltage if it is bad anyway the boom that may be the issue?
On a side note.....with just one injector plugged in this thing runs like a scawlded dog!!!!!! Im not kidding! It really seams to have better throttle response and power than ever before. ON ONE INJECTOR! If it weren't for the idle being so stinking high it would be great. hey Mules....I'm assuming that you have the same type setup or that you are just very knowledgable about it but is there anyway that you could mayber take a picture of the different sensors and where they are at on the motor? I know where the 02 sensor is but really don't have a clue on any of the others that have been mentioned above. Thanks so much!
will see what i can do in next few days for ya.
Sounds like the alternator is weak/bad, but probably not the cure-all. I doubt revving would kill the O2 sensor.
Something in the computer is causing it to dump fuel. Try unplugging the temp sensor (for the computer). It's a 2 wire probably in the water outlet or close by. This should (A) set the check engine light (B) put it into limp mode taking the O2 sensor out of the circuit, running the system on a pre-programmed mode.
But first be sure and check all your sensors and vacuum hoses. Hmm...a stuck open EGR would also cause a lean condition...I know snap revving an engine can un-stick and EGR...wonder if it could make it stick? Check that first.
Well a new 02 sensor and replacing the vacuum hose from the TBI to the MAP Sensor didn't do a durn thing! The old 02 Sensor looked horrible though so glad I replaced it. The PO made is really easy to change it out where he installed it. How do I check the amps on the alternator well i guess I could just take it off nad get it tested at the local auto parts store. They know me by name there now. It is like they are rooting for me to get it fixed. I'm also thinking about the return line from the TBI to the tank. After I shut the motor off you can here dripping. keep the help coming please. I have to drop the tank on my F250 tomorrow and clean a clogged sending unit so probably no work on the Jeep till Sunday after church.
Not really the amps, but the voltage produced at idle. You should check this on the vehicle, those off the car testers aren't the best...
Dod you check the egr yet?
You should be able to disconnect the return hose and blow through it.
