How much does a scrambler weigh?
tower210
Olathe
KS
Making arrangements at my u-haul place to pick up my new addition (pix coming soon!!) and they are working their way through the usual; what are you using to tow, what are you towing, ect. No, problems arose, but out of curiosity I asked how they determined the suitabiliy, and he responded that it gave the towing capacity for my vehicle and the weight of the vehicle being transported. The list the weight of a 4x4 scramber as 2782 lbs!!! That sounds far lighter than I would have guessed. Anyone know what your scrambler weights?
KK
I've never weighed mine, but the sticker from the factory put the curb weight at about 2,700 lbs. Other than bigger tires and a winch, I haven't really added much to mine, and I've removed the hardtop and doors, so I think mine is still in that same area. The original Wrangler was heavier than a CJ, and I read recently that the base model was 3,100 lbs.
Junk in the trunk?
That's amazing!! From 2800 to 4100 is a serious gain. I could see 30 lbs per wheel (bigger tires) and 250 lbs for the 360 and 100 lbs for an automatic, maybe 100 lbs in bumpers but we are still no where close to 4100. Honestly the 2800 is the number that I am most shocked at. Most modern cars weigh 3500 or so. All the greenies want milage and all the safties want airbags (10 at 25 lbs each), if we could have modern technology (read engine/transmission) in a 2800 lb package, we would improve stopping (safety) and milage :cheers:; not to mention they would accelerate, turn, and climb better.
KK
Wow! Those are some light numbers. Mine weighs a bit over 4100 lbs....I guess it's a bit overweight. You can look at a thread here where I weighed it.... https://www.cj-8.com/forum/showthread.php?t=25429&highlight=scale
KK
There some parts that definitely add weight...Dana 44's front and back with larger brakes, the rocker guards, winch, 5x33 BFG-M/Ts, bumpers and spare tire carrier, roll cage....they all add up. The 360, IIRC, isn't a lot more than a 258 I-6. When you add stuff, you do have to upgrade brakes and other parts.
In the VIN decoder, CJ8's are listed as 4150#. See here: Vin decoder We've all got "E's" as our 9th digit, which is GVW. TMYK...
When mine was somewhat stock, I ran it over the truck scale just down the street. Came in at about 2800. That was with a 350 and 33" tires, aluminum wheels, and no top.
Now, it's probably much heavier. I've got about 100' of 1 3/4" by 1/8" wall tube in the roll cage alone...
Good point - it makes sense based on what people are posting as actual weights. CJ7s are listed as 3750 or something...
I weighed my 7 at a CAT scale with the soft top on, a rear bumper that weighs probably 500 lbs (I'm not kidding), 30/44 axles, AMC 304 (which is only a couple lbs. heavier than a 258), T-18, Dana 300, 33"s with steel rims. It came it right at 4150, which I thought was funny since that is GVWR for a CJ-7.
My CJ-7 wieghed in at 4400 lbs. it will be interesting to see when the Scrambler weighs when its done (TDK frame, 60s, and a bunch of other stuff)
weight
Weighed the truck,trailer and jeep today.........16,700lbs..............truck weighs 7040lbs............trailer weighs 4850lbs....................and the scrambler weighs 4810lbs:eek:
My CJ-5 came in under 2000lbs with a fiberglass body no top and a 6 cylinder with a t716 4 speed and stock axles. I was shocked to see that number but the scale was certified.
That 2782# number is probably no top, no doors, no gas, 4 cyl. manual. Top and doors were options.
4600lbs... 1/4 of fuel and my 200lb a$$ in it.
Here is another data point. It looks like the heavy title goes to me!
4,900 total. Front axle: 2,360 Rear axle: 2,540
No cargo. Just a basic toolkit, Safejack kit, and a full tank of gas. (23gal). I was not in it.
Setup like the pic shows.
I’ll have to get my 7 weighed one of these days. I’ve been wondering about that for a long time, especially changing out and adding things over the years.
