Temporarily halted work on my speedometer issue. Decided to get rid of one more big box of parts I have by installing them: Mopar MPI.
Some pictures of all the parts.
Picture of the included fuel lines, PVC lines, accelerator cable, and other assorted tubes and pipes.
Picture of the wiring. This is all of the under hood wiring. It comes preassembled, labeled and wrapped up. This will save a bunch of time.
One last picture of the stock carb/ignition system.
I have been dragging my feet on doing this installation for a few reasons.
#1) The jeep runs perfect with this carb and ignition system. Good power, no stalling or missing, starts super easy, etc. It runs perfect. It has no misses at all. Runs as smooth as a sewing machine. But, I know the MPI will improve upon this, plus add power.
#2) The weather has been really nice down here lately, so I have been driving this jeep a lot. Hard to temporarily disable a perfectly good convertible when the weather is this nice.
#3) I just got this drivable after a long rebuild, so it makes it that much harder to make it undrivable again.
Well, no since delaying this installation. Last night I started removing the factory parts to get ready for this install.
Parts I removed last night:
drained radiator
removed fuel pump and fuel line from pump to carb
removed accelerator cable plus PVC lines and vacuum advance line
removed power steering pump from the intake manifold plus both drive belts
removed factory carb and intake and air cleaner
removed factory coil, distributor, spark plugs, and plug wires.
Pictures of the stripped down engine.
That is as far as I got. This particular jeep already had all of the factory emissions/computer controlled carb pieces/vacuum line mess/pulse air system parts removed by a previous owner. That saved some time since all these parts were already removed.
This is where I stopped at. I need to make sure that I am at TDC on #1 (compression stroke) before I go any further. Before I pulled the factory distributor, I pulled the plugs and turned the motor over until the rotor was pointing at the #1 plug wire. But, since I don't think my harmonic balancer has a TDC mark on it (the previously installed Mopar harmonic balancer that must be used with this kit), I am not 100% sure If I am at TDC compression or 180 degrees out.
I will probably drop the factory distributor back in, place my thumb over the #1 spark plug hole, and then turn the motor over to feel the air blowing out. This should guarantee that I am at TDC compression. I don't want to pull the valve cover off to see what the valve springs look like since it is not leaking. Any other suggestions for ensuring that I am at TDC compression??
