It lives, running and shifting pretty good.
Trying to figure out shocks and bump stops.
The corner armor looks good...been thinking about it for the CJ5 as well as the Scrambler... did you end up making it or buying it?
Nice DOF Trailer!!! What make? PJ? And congrats on getting her running...
7jeeps7kings
Well the Scrambler performed pretty well in Moab. It did pick up it's new name 'Rat Rod' Scrambler!
Had to drop fuel tank, sending unit filter sock was not positioned properly and would only pick up fuel to half tank.
Also having some other fuel issue, thought it was fuel rail pressure regulator as we were only getting around 35 psi.
Changed pump and regulator and pressure still stayed around 35 psi?
We used some line pinch pliers on the return line to adjust the pressure to around 46 to 47 psi.
Had NO fuel problems after that. Not sure what to try next? Really don't think the pinch pliers should be a permanent fix!
Can't take full credit for the band aide fix idea.But what a cool and genius way to get through the weekend. Nice band aide
Going to try and bring at least 3 trail rigs. Swapping a trans in the Rat Rod.How many are you guys bringing to the nationals? Just wheeling rigs,or some pretty ones also? Is that Ken's silver one in the group shot?
