What did you do with your Scrambler today? September 2013 version
Installed early birthday present. New Omix front turn signals. They look great!! Much more even light reflected.
On a second note its shocking how bad the quality of the detects in the sockets for the 1157 bulb are. You almost couldn't tell there was any track there.
Crown are the same way... if you twist too hard, the bulb will spin all the way around in the socket. If you tug on the bulb, it will come out without even turning.
Failed inspection. Front and rear brakes. No biggie. But for some reason my tail lights and reverse lights don't work. Brake lights do. But the big thing is a crack in the frame at the front by the leaf spring hanger. Ugh.
Dain
Sorry to hear that Dain. I guess the bright side is you found it before something bad happened...
Dain
I bet Curtis a fix that crack for you no problem !
My reverse lights didn't work when I started the Jeep
The connection under the steering column was bad
All I had to do was squeeze it
You are the second to suggest Curtis. Will shoot him a PM/call.
Gonna go out and see about the light now.
Dain
Installed some steel WFO front shims to correct the caster lost from installing the longer shackles to level the front. Decided against warranty replacement on the fronts, for $80 freight they'll just do the same thing. Still looking to links and coilovers. But, for a temp fix it drives nice again.
Last night I installed my borgeson steering shaft
And today I installed my warn rear bumper/ tire carrier
Got a new (used... but new to me) Tuffy box. Need to clean it up some and replace the weather stripping. Then need to decide if I want to mount it near the tailgate like it is now, or move it up against the bulkhead.
At least I wont have to worry about my rifle being grabbed out of the cab this elk season. :eek:
Moved the 8 to the other side of the yard to make room for the red 7.. and after one year got my yellow 7 on the road again after her accident. .. She test drove with no problems :) i Have to register her today at the dmv. Hopefully.
Sent from my SPH-L900
Did the Rampage H4 light upgrade with ARB relay kit. Also, added a tube bumper. In the heat of the York jeep show I ordered the wrong one. This one has plastic end caps :( To much trouble to send back so I'm going to keep it. Yes, it's becoming a Quadratec jeep...
No, problems at all doing the lights. I didn't do before and after shots, but they are WAY better!!
Took the ramhorn manifold off my 67 corvette and put on the scrambler because I don't have time to order or find one and going on trail ride Thurs.....
Truck
Truck
Yes....You are...
Took the XXXXX off my 67 corvette and put on the scrambler
I didn't think I'd ever see this posted........
I'll haul that piece of junk (the 67) out of your way for you, I know it's takin up garage space. :)
NEW RULE. If you mention anything you did with a classic car or jeep in this thread, you must include pix!!!! No Exceptions!!!
Im waiting in the nyc dmv to get a title of one scrambler in my name and the plates for my cj7.
Do I have to take pictures of my new plates then?
The LJ Rubicon is getting serviced, so drove this one to work today:thumbsup:
Canoe trip
Getting scrambler ready for a canoe trip with the 1967 m416 in tow.
Went wheeling today and yesterday with Truck, Dustin, Jess (Dustin's sister), Richard/Grantshire, Nick, Rusty and others.
