Got it ready-er for winter. Scrubbed down the ratty half hardtop first. This top has apparently been painted inside with what I can only describe as sorta-paint. It sorta stuck and sorta peeled. When I first brought it home (in a thunderstorm, with no muffler, barely enough fuel and no fuel gauge, no charging system and the top and doors rattling so bad that I told my buddy to back off a little in case the top blew off) my wife asked me if it was snowing. Odd since it was summer... The paint was just flaking off with every bump. I took a stiff nylon brush and some soapy water and removed all of the loose paint and the mud from a long forgotten playday with the previous owner. I had to take the metal strip off and put it on the Fiberglas windshield frame with bolts and nuts due to most of the holes now being in the shape of slots from the loose sub-par installation before. I knew the doors and top had a pretty decent gap and that I should re-align the doors. I also knew that there was no way I was getting the bolts loose on the doors without a torch, and that I'd probably still end up stripping the head or breaking at least a couple of them off in the door. So, Lowes weatherstripping to the rescue. It actually sticks really well and completely sealed the doors to the top. Done.
I screwed the rubber boots down for the transmission and twin sticks and got rid of a TON of air coming up through the trans tunnel.
I stopped by a little muffler shop in the hood a few days ago and bought a used $20 Delta 50 series Flowmaster just to see how it sounded. I think I like it. It's not too loud at idle but has a little rumble when the skinny pedal gets pushed.
I had a slow leak on one my tires. I found a plug that had a leak so I pulled it and replaced with a better quality plug. The one I pulled almost came out in ribbons. I've never seen that before. No leak after 48 hours.
I drove it to work yesterday after dropping my five year old off at preschool. She loves riding in the Jeep. It drives good, steers good, stops good and idles good. All improvements over when I brought it home.
It has good heat, but I need to investigate a pretty substantial amount of air coming in under the dash. It feels like its coming from above and to the right of the steering column...
As for now, I'm just gonna drive it some.
