I bought another scrambler !
Ordered pressure hose today
Need to go to yard and source the return hard-line from the wrecked scram
It's already paying off !!
Sent from my iPhone
Ok. , so the pressure line from napa ( special order ) was wrong , did not have the correct bends to be routed under the radiator
So I got lucky and removed both lines from the white scram
Also lucky that the pump side metal line was not bent like a normal 6cyl line , and I was able to use my pipe benders to make it work
Line installed without bending it had the line to tight to fender and in a bind
After some bending and twisting ( few beers and a lot of cussing )
Sent from my iPhone
So the front end is in !!
Still need to check torque on u-bolts and pitman arm nut and add gear oil to front end
Front end - spring under 4" lift spring
Rear end -spring over 2.5" lift spring
Sent from my iPhone
Got it turned around , had to use emer brakes because I don't have any fluid
I got the heat on and I'm going to start on the rear
Going to remove the 60-2, put in d44,change out. 2.5 springs for 4"
Got to cut off the extra shock mounts. ( pic later
Sent from my iPhone
Nice. :thumbsup:
But where is all the white fluffy stuff? And what is that green stuff on the ground? :shrug: :wave:
Piece of cake. Be nice if the "New" one will go in and hook up as easily. In same amount of time.
Rear shackle bushing are shot !!
Luckily shackle bolts unbolted from the frame because I could not get shackle bolts out due to exhaust pipes in the way
Sent from my iPhone
Looks like its on its way back to "normal"! I love watching and learning on this site... Looking good.
Got the bushings replaced and shackles reinstalled, also got the extra shock mounts cut off the frame
Sent from my iPhone
So now I'm prepping the rear leaf springs, had to remove this thick shim that Is not needed on our lifts
The centering pin was ruined so I had to replace it with these 3/16 inch Allen heads
Also had to use the die grinder and open up the hole on the spring perch, just a tad
Sent from my iPhone
One man install
Pics alittle dark .,
Still more to do , but it's on the ground
Sent from my iPhone
