TFDScrambler
- Tulsa
- OK
I got to go to work yesterday and spent a good 3 hours reading through spankyjrs build. That one is just amazing. The dedication he put into that build is unsurpassed. Beautiful ride and not a single part went back on without some paint. It makes me wish I had more time and deeper pockets, but the good Lord has blessed me immensely so I will just keep on keeping on.
So I have a few updates.
All of the body mount bolts came out without a twisted nut hidden in the body.
Next I attempted to remove the factory roll bar, with some slight issues. Those dadgum torx heads are garbage and would strip if I just looked at them wrong. Got 10 of the 16 out. I think the P.O. had stripped some of them while putting them in. One of them is broke off in the nut but I think I will be able to get it out from underneath with a pair of channel locks. The ones that were stripped got a 10mm nut welded to the top of them and I eventually won the battle. The roll bar is setting next to the house now.
Next on my punch list today was to finish tearing all the bedliner out of the bed area. I started it two nights ago but it proved to be really in there. There were two layers and the one on top was some tough stuff. Very hard and adhered to the older liner extremely well.
I could feel there were areas where the old liner had let go and I was a little scared to see exactly what condition the metal underneath was going to be in, but to my surprise it wasn't that bad. Some minor surface rust but overall clean.
The worst areas I have found yet was the obvious area underneath the rollbar plates. It really isn't that bad though and I ran a wire wheel about halfway over one to check it out and it is pitted but not all the way through yet. I am keeping my fingers crossed that when I pull all the liner out of the cab that the floors are as fortunate as the bed.
Also began to pull the dash out today but stopped when I realized that I should probably make a little wiring diagram of where it all really goes. I don't really take notes or have any method but I know I can count of looking through some of the builds on this forum and find most of what I need.
I do have a question for you guys. The following picture is of the top two bolts on the drivers side motor mount from outside the rail. I don't quite remember if it was in the forward four holes or the back four. I have six holes (two positions) that it could go into. I am quite sure that it's the front four but I may be wrong.
So which is it?
So which is it?
). Then I went and picked up my 1st grader from school and hauled a bunch of boat parts out of the garage to my dads shop for storage until I can get that project started. I need all the garage space I can get so I can get this tub off on wednesday. My next few items on the list of to do's for this week on the scrambler are as follows:
