Essential Tool & Parts to Carry Along At All Times
AJ2393
Scrambled in the Head
Silver Member
North Dighton
MA
I know this probably an odd post, but I have been pondering what tool and extra parts I should try and carry along in my jeep in case of a breakdown or emergency. This is more of a street Jeep, so I am focusing on roadside breakdowns and emergencies. I only have the area behind my seats, as this is a two seater with the half hardtop /bulkhead combo. I already plan to carry the following:
1. Basic Hand tools ( 1/2 drive sockets - standard, torx bits, vise grips x2, hand wrenches- standard, screwdrivers, breaker bar, 1/4" drive small socket kit - standard)
2. Extra wire in different thicknesses, connectors, electrical tape, and crimp tool
3. Extra fuel filter, ignition control module (stock), coil
4. Jumper cables
5. I have mounted 2- 2.5lb Haltron fire extinguishers inside the Jeep already
6. If room I have room - Extra fluids such as oil, coolant, etc.
A lot of you have more experience than I do, so I am sure there are some critical items I am missing. Please give me your thoughts.
Be sure you a) have a jack (and lug nut wrench) and b) the jack works. My first Jeep blew a tire not long after I bought it, it was 10pm on the interstate a little south of Syracuse. Not much traffic there that time of night on a Sunday. I had no jack, this was before cell phones, and I waited about 2hrs before an off-duty cop stopped and called a tow for me.
Duct Tape, cable ties and bailing wire.
oh and a hammer!
What's the baling wire for???
About 20 feet of stranded wire and some crimp connectors. Side cutters. Electrical tape. Pliers. Long nose Vise grips. Small pc of Fine scotch bright for contacts.
Sent from my SPH-L900
In lieu of a bunch of wrenches and/or sockets, get one of the dogbone wrenches that has the rotating heads and carry an adjustable wrench for things where you don't have room for the dogbone. If you're junk is mostly stock, you can get away with one dogbone wrench and the adjustable wrench in lieu of a lot of others. Those with a pair of vice grips will take care of almost anything you'll come across.
I found a screaming deal on a pair of metric/standard (I have modern stuff that needs metric :banghead:) at my local ACE and threw them in the console. One of the best tool adds I've had.
Radiator stop leak, the kind that's dry and looks like a plastic container of pepper.
These are all terrific ideas, keep them coming!
On my red Scrambler, which I drive cross country, and has MPFI:
1) all the critical engine sensors (O2, coolant, crank, idle air, etc)
2) spare fuel pump/relays/filter
3) u-joints/tie rod ends
4) wire and connectors
5) bolts, nuts
Make sure you check all fluids/grease everything before leaving. Spend some time underneath, look for abnormalities. If you have been having any minor "issues", fix them before you leave, they wont fix themselves:twocents:
If you are running stock ignition/carb, then spare ignition module/coil, fuel filter, carb cleaner.
When I was running a T5, the last trip I made I carried a T176, bell housing, drive shafts, shifters:rotfl::rotfl:
AAA Plus..... 100 miles of towing if you need it. That'll get you home most of the time.
+1
I stopped by AAA on the way home from test driving my Scrambler. I had the card before I had the title two hours later... Plus it works on ANY car you drive.
Can be used to hold stuff duct tape, cable ties and vise grips cant hold. ie. exhaust and other hot stuff that would burn or melt the other stuff.
My console contents....and AAA Plus in my wallet.
+1
+2. I wore them out without a complaint from them with my icm problems before I went hei dui.
I actually don't carry a spare as I'm never more than 100 miles from home.
Spare relay for HEI power....
I went the gear wrench plus vise grip rout....
Great list that I agree with all of them. I also make sure I have a breaker bar or a length of pipe that I can fit over the end of wrenches to use as a breaker bar for the stubborn bolts.
