- Biloxi
- MS
I guess you don't need to worry about end caps for that bumper anymore![]()
O those poor end caps
Don't worry, the end caps were broken before I got it
Don't worry, the end caps were broken before I got it![]()
And you said this bumper was damaged?? You shoulda yanked it before abusing it, for you could have got two spare transmissions for its value for the red scrambler !
They were??And you said this bumper was damaged?? You shoulda yanked it before abusing it, for you could have got two spare transmissions for its value for the red scrambler !
Lest anyone forget !
Aww that picture makes it even worse![]()
I don't know what Jeep was thinking using plastic end caps on a rear bumper, they are super weak. I think an original magazine cover shot of a "Scrambler Review" shows the end caps being obliterated.
. spanks knows we are ribbing him. And if you knew the legend of the bumper ends cap you would see why
I should put the bumper/end cap remnants on eBay and see how much I get for it
"Here we have a 100% authentic spankrjs modified 100% factory stock resto-mod stock factory rear Scrambler bumper, super uber rare, 1 of only 100 made in 1984, one of only 3 known surviving examples out of California, and the only one with Earth Day and Animal Institute of America bumper stickers. This rear 100% factory stock NOS resto-mod rear bumper will be the crowning achievement of any real Scrambler aficionado ..............................."
This Scrambler has been doing yard clearing duty the last month or so with the Harbor Freight trailer, been working out pretty good.
I have temporarily taken this one out of commission to fix a few nagging problem/issues. When I rebuilt/finished this project Scrambler, I did not change any under hood parts, everything worked. Now, some issues are starting to pop up:
1) Starter Bendix is super weak, starter disengages early
Easy fix, change the starter.
2) Squeaky belt, water pump front bearing shot, fan is about to fall off
Easy fix, change the water pump.
3) Since draining coolant, change out the coolant temp sensor (it shows the coolant at 123 when it is 190)
Easy fix, change the sensor.
4) Address some squeaks/rattles from the full hard top
Hopefully easy, I will update with more pictures/part #'s. Basically, three issues:
A. I am using the wrong weather stripping on the lift gate so it rattles.
B. I am using the wrong weather stripping under the top. I need to use rubber, the foam is too weak.
C. I need to repair the little angle pieces that secure the hard top to the tub, one on either side of the lift gate opening.
I will update with more pictures and info when I start fixing stuff![]()
