Yep, mine too
I let the "real" mechanic at work look at my Scrambler last week, he couldn't find any mechanical problems. He seems to think, like me, I just didn't rotate them enough. But, and I will have to take pictures, the wear on the fronts isn't like "normal cupping", the leading edge of every other tread block is wore, almost like a defective tire issue or something
I'm just going to throw the fronts on the back and wear them back down
So it's been awhile since you did the AX15 swap. Are you liking it better than the T5 set up? How many miles and any issues?
Yes, I like the AX15 much better then the T5, it hasn't blown up yet
I am running a Toyota truck version AX15, so the gear ratio's are almost identical to the T5, especially the deep first gear. So, driving the Scrambler with this AX15 is almost identical to driving a T5. A few of the ratios are a bit deeper then the T5's, just a little difference, so I actually like this AX15's ratios more then the T5's, if that makes sense
No issues and no problems, not sure of the miles
I drove it from Biloxi, MS to Moab, UT, and back, and to Hot Springs Arkansas and back with no problems, so
I think I have close to 4,000 miles on the swap, no problems.
The T5 in my green Scrambler has a B&M short throw shifter, which I love. My AX15 in the red Scrambler has the standard, stock shifter. The short throw shifters are very nice, but I don't have any problem with the stock AX15 shifter, the shift throws are just long compared to the B&M equipped T5.
