In my best Britney voice, "Whoops, I did it again.." LOL
Hard to see, but that's yet another T5 down. All the past T5 experience helps greatly, only took about 2-2.5 hours start/finish to have it on the ground
This T5 has not catastrophically failed, just a little noisy. Judging from the "Borg and Beck" stamped pressure plate, plastic front bearing retainer stamped "Borg Warner", I don't think this T5 has ever hit the ground in its 120,000+ miles.
I bought this Scrambler back in 2009 from the second owner, this is actually my first Scrambler. But, since 2009, this Scrambler has been patiently waiting, while I completely rebuilt my red Scrambler, completely rebuilt Tommy's YSI, rebuilt/modified/repaired my Tan Scrambler, put Josh's tan Scrambler back together, got YSII running, plus swapped out 5-6 transmissions in the red Scrambler
I am sure I am forgetting some stuff, too
Anyway, this one is in great shape, but does need some work. The clutch is weak, the T5 is noisy, the front output shaft bearing in the Dana 300 is loose, and the engine feels tired. I have been meaning to work on this one, but other stuff kept popping up, and I kept on procrastinating. Since my surgery, I have been trying not to keep putting stuff off, never know how much time you have left. So, after replacing my red Scrambler's engine, I decided to immediately jump on this one. I am going to do a pretty good chunk of work to this one, hopefully finish it up before my next CT scan in March
This is my "stock" Scrambler, all though that is not 100% true. It has been repainted back to its original color, repro decals, Moser 1 piece rear axles, 1" Superlift suspension. I am not really modifying this one, never planned on it. This one is to keep close to stock, but it is not so "perfectly original" that I feel like I can't enjoy it, if that makes sense. Anyway, here is the game plan:
1) Engine - I am currently having Hesco rebuild the engine that came out of my red '83 Scrambler. Nothing fancy, just a stock rebuild. I think the block is being bored 40 over to clean it up, crank turned down 10 thousandths.
2) Fuel/Spark Management - I am adding the Hesco/Mopar MPI kit to this engine. I know I spent a long time "restoring" most of the factory emissions/carb/computer on this Scrambler, but the MPI is just so nice. I forgot how much fun my red Scrambler was to drive, this one should be a blast, too, especially with stock tires. I am going to keep all the stock carb/computer/wiring/doo hickies I remove.
3) Clutch - resurfacing a flywheel, adding a new ring gear. Going to replace the clutch with a "stock" type unit, not sure with what, yet. New pilot bushing and throw out bearing, too.
4) T5 - my arch nemesis!!!!!!!!!!!!!! Plan is to just rebuild this one and keep on rocking it. When i disassembled it, though, I found the source of the noise. The cluster gear, where the rear bearing rides, is pitted, which causes the roller bearing to roar. So, going to replace the cluster gear, too. I hope a T5 can stand up to a 258, 3.31 gears, and 30" tires. BUT, I am worried about the increased power from the MPI. I am going to run this T5 till it blows. IF/WHEN it blows, well maybe then we can talk about AX15's. It only took blowing three T5's in my other '83 before I upgraded!!!!
5) Dana 300 - plan on rebuilding it. No upgraded shafts/gearing needed. I haven't tore it down yet, but hopefully all the big expensive stuff is fine, hope so!!!!!
6) Misc. - plan on just mounting an external fuel pump for the MPI. This is the newer style 4.0 injection with just a single line. If it becomes a problem, I might swap to an in tank pump. It's easier to drop the 15 gallon tanks vs the 20 gallon tanks. I am also going to have new exhaust installed. The existing muffler feels really heavy, and all the pipes are just clamped together.
So, a new engine, fuel injection, new clutch, rebuild the T5 and Dana 300, with about 6-7 week time frame. Shouldn't be too bad.
A few quick pictures for posterity.
I had to put this one on jack stands, 1" lift springs and 30" tires does not allow for a lot of room underneath:
Most of the parts out, ready for cleaning:
About 2.5 hours to pull all that stuff, about 8 hours cleaning, and still not finished cleaning!!!!!!!!!! The parts were not really too oily/dirty, but 30 years/120,000+ miles of use made me wish I would have went to work and drug the steam cleaner out.
Since my garage is small, my game plan is:
Step 1 - remove driveshafts/skid plate/transmission+transfer case/bell housing/old clutch
Step 2 - clean all the above stuff
Step 3 - rebuild T5 and Dana 300
Step 4 - remove old engine and all stock carb/computer/emissions stuff
Step 5 - install new engine
Step 6 - install new clutch, install clean/rebuilt bell housing, T5, Dana 300, driveshafts, skid plate
Step 7 - finish all the under hood MPI stuff
Step 8 - drive and enjoy
I will post some updates/pictures of anything interesting, that's it for now
