Someone called it a TJ 6
Now for the shifters. The Jeep has a twin stick 4.3 Atlas t-case, a 2.77 geared KluneV with a 700R4 driving it all. So 4 shifters have to fit in there some where.
Base plate of the Atlas and KluneV shifters. I am adapting the KluneV to the 3rd shifter for an Atlas 4sp t-case.
Where it will sit between the seats.
Working on the tunnel cover for the Auto shifter and where the Atlas cables will come out.
The Auto shifter is a Lokar floor mount cable shifter.
And as usual there are more pictures in the link in the signature.
More shifter work done. Working the shifter end of the cables and routing through the tower.
Ah, I was confused by the pattern for the twin stick shifter boot on the front cover. Very cool idea.
Love everything about this thread.
Confused a few with that one, a couple of my buddies I sent pictures to had the same look of what the..... is he doing with 6 shifters!
I wish I was assembling all this for the last time.......The body has to come off and go back in the rotisserie at least one more time, but I am trying to make it only one more time. Trying to put every piece of stuff I have on it before taking it a part again for final body work and paint. Then while it is in the rotisserie I want to get all the mechanical stuff finished on the frame like brakes, brake lined, fuel lines, air lines and just before the body is ready to go back on drop the trany for rebuild and seal and fill the KluneV, T-case, oil change for the engine, so once the body goes back on only the wiring is left...I hope!
A few more little things done.
Jeep Air Heat/AC unit mounting figured out
M.O.R.E. Dual battery tray for a JK mounted, just used the tray there were other brackets I didn't use.
Home make supports for the battery tray
Cross braces on the roll cage for the shoulder harnesses of the 4 point harness I will be using.
Been getting a little ahead while waiting for a storage area to be built to put parts when I take this apart again
So I started on the front bumper.
Base plate from A to Z fab and 8274 winch mounting plate from TMR
Hood hoop from Blue Torch Fab. I didn't have the tube and this was cheaper that buying the tube and bend it here.
All tacked up.
Welded out and ready to go to sandblaster.
76-80 era brake booster mounted
Same era brake/clutch and steering bracket installed. Clutch pedal removed, running an auto.
Having trouble deciding if I'd rather have this build or one of the FC builds, but glad I get to see them all :drool:
I'm sorry if i missed it... Is that a TBI 4.3L v6? Obviously it would be different for me in an 8, but how did it fit? Looks like factory manifolds may have clearance.
Beautiful work on the cage and metal fab.
It is a 4.3GM V6. TBI late 80's the block is stamped 89. I am using at 2000TJ frame and I used an Advance Adapter Kit for installing a V6 into that year TJ. Using the AA kit and how much I stretched the frame (8.5" bring it to 101.5 in C to C of the axles) I ended up sliding the tub back over the rear cross member by about a 1/2 to make a little extra clearance between the fire wall and the distributor. The AA kit instructions for the TJ said "one might have to beat the fire wall back a little to make clearance for the distributor". And that would have worked with this body as well. But being I could cheat at the other end I did it that way.
Yes it has the stock manifolds and they are inside the frame rails, I have not tried running exhaust pipes so I don't know what that will bring yet with the front drive shaft being on the drivers side. It may take a hot rod style through the frame trick but don't know yet. It will be coming up soon though. The body is fixing to come back off the frame and go back in the rotisserie, while it is in there this time I am shoot to get all the lines and mechanical stuff done on the frame so it will be ready when the tube is painted and ready to go back on.
BigWalton, I have often thought about an FC build. I think it would be cool to build it heavy duty enough to carry a popup truck camper to cross county back country trips.
Do that ^^^^^^
A simple solution if you are not trying to eek every little bit of HP out of it, is to find a passenger side manifold off of an early 3.8 chevy v6 (think malibu, monte carlo, el camino) and reverse it so it exits toward the front of the engine. Then you can go down and around the front of the oil pan and Y pipe it into the passenger side exhaust.
I have also done it with passenger side factory tube manifolds off a later 4.3, but I prefer the cast iron manifolds off a 3.8.
Great Idea I will keep that in mind, I hope I am not that far a way from getting the body of and starting an the chassis again.
A little more work on things while I get ready to start painting and coating things.
Cut holes in the after market dash for Tach, Clock, and Trans Temp Gauge.
All the Stuff in the dash is SpeedHut.
Cut hole in dash for my sPOP switch panel.
Built and added support bracket to the Electric fan and Shroud to fit the grill and radiator.
A view from the bottom.
Took the summer off for what end up as a 102 day round trip to the Canadian maritimes. Was back 2 weeks and went to Hawaii for 2 weeks. Now I can get back on this. When I left I was working on the chassis, fuel system, brake lines, air lines for the lockers.
