Finally ran it almost out of gas last night.
Stopped at a red light, hard acceleration into a 90 degree turn from a stop, got that little "no fuel pick up hesitation", smoothed out on the straight away, stopped at the closest gas station.
Originally, I was going to pump out the remaining gas, but what ever is left in the tank is burning fine.
I have a 15 gallon tank, OEM gauge , this is where the gauge was at:
And what it took to fill it up.
Happy about that. I can "safely" suck out 14.2 gallons out of the 15 gallon tank. I was worried about this before, with regards to how I installed my in tank pump, but I am not worried anymore. On a flat, straight highway, I could probably suck the tank dry.
And full, happy my OEM gauge is still working, probably just cursed myself.
I filled it up with 93 octane "pump" gas. I plan on driving the piss out of it over the next few weeks, so not too concerned about the "E" factor.
Anyway, no AC on, drove perfect, all the way to the gas station.
Filled it up, started it up, turned the AC on, drove perfect for about 10 minutes mixed city/back highway driving. Got it on the four lane, 70 MPH, after about 3-4 minutes, check engine light, same Code #51 Running Lean.
Pulled over, Turned the Jeep off. Key back on, cleared out the code. Immediately started it back up, no hot restart issues. Turned the AC off, drove it some more, no check engine light, running fine, O2 sensor working properly.
So, it would seem that somehow the AC is a contributing factor. It does put a slight load on the engine, but not that great of a load where the computer should not be able to compensate?
Temperature with no AC = 193-196
Temperature with AC = 196 - 203
I don't think the slight increase in operating temperature is a factor, my LJ runs at 210 all day long.
On the electrical side, the computer is seeing a constant 13.9 volts, AC off or on. The larger alternator makes this possible. With the stock size alternator, the voltage would dip below 12 with the AC on.
So, I don't think the slight electrical consumption from the AC fan is causing a "brown out" condition.
On the compressor, when the clutch engages, I do see a 100 RPM drop at idle. I drilled a hole in the throttle plate to allow enough air flow at idle because the IAC valve could not compensate. So, at idle, no AC, the idle speed is 836 RPM. With AC on, 736 RPM. The AC works perfectly, so I do not think I have some weird compressor issue causing a super parasitic drag on the engine, especially at 70 MPH/2,000 RPM.
I called HESCO this morning and talked with them about this issue. They, like me, are thinking/suggesting a simple fix first, swap in a new O2 sensor and see if that clears it up. I have a spare already, so easy enough to do.
But, seems strange that if the O2 sensor is bad/contaminated, it would only trip the code with the AC on? The current O2 sensor is a Mopar unit, with only maybe 1,000 miles on it, but who knows?
