I think you need to have a chat with that goat though.
Where did you get the rubber seal that goes between your windshield frame, and hardtop. I have the same top on my Scrambler, and no seal. I have an air leak there, and that rubber seal looks like it would do the trick.
Thanks
That's just stick-on weather stripping from my local hardware store. I added it. They way they have it sealed "as shipped" is good, but I wanted to double-up. Does yours have the original seal method intact?
My top is only a couple of months old, so the seal is in good shape. I just got off the phone with Mike from Xtreme Tops, he said to put a piece of weatherstripping under it and it should cure the problem. That’s what I had in mind anyway, But your set up looks bullet proof
I LOVE mine. But it's not "perfect". Annoying thing is that there's a little bit of interference with closing the driver's door. **BUT** this could also be due to my old worn our door hinges causing mis-alignment.has anyone had any issue w fitment w these tops?
Looks like theres only 1 producer for cj8 hard tops anymore, but lots of online distributors.
Does anyone know of any other competitor?
