- Biloxi
- MS
Good progress. Would you be willing to post up a pdf scan of the antennae mount template? Thanks.
Should print out on 8.5"x11" paper.
NOTE - It is "backwards". To line this up correctly, the writing side goes toward the body.
Lots of progress here. The Spring Special still chirps through 3rd gear.
Looks like Tommy is making great progress.
Just a little bit of work last night.
Cleared out 8 painted brackets and a bunch of hardware:
All of this hardware is 7/16" stuff. Grade 8 would have been preferred, but 5 should suffice. I ended up using 4" long bolts through the frame rails, 3.5" is a bit too short IMO. Also, 7/16 washers have too big of an OD to be used in many places, but 3/8 washers will fit 7/16 bolts and have a smaller OD.
And one big part off the floor:
I still need to adjust/align it, then tighten up all the bolts.
Not a lot, but a little bit of progress every day is better then nothing.
That's it for now![]()
Our local Wilco actually has grade 8 SAE washers in bulk! The SAE washers are a bit thinner but have a smaller exterior diameter and fit the bolt better. The grade 8 designation should make up a bit for them being thinner.
Yep! That’s the best. Lowe’s 3/8x2 1/2-$1.58Tractor Supply has Grade 8 by the pound.
Looks like Woody was trying to help the PM too, but failed miserably.
Parts MonkeyWhat is the PM?
