firefighter736's Build Thread
Really nice looking build. Great progress. I see you've got what appear to be LED tail lights, true? And also a TJ license plate bracket?
Thank you. Yes, on both, Went with the Savvy Offroad tail lights and a TJ bracket. The Savvy light's don't work well with a stock bracket so I rigged this system up.
And thanks - the shop is coming along nicely. We put a ceiling in it over Christmas break so now it will hold heat.
I like what you did with the tail lights and licence plate holder. :thumbsup:
Had my buddy work the throttle and my girlfriend supervise the first firing of the 5.0 with open headers
https://youtu.be/5STT5Ie04_c
Pretty exciting moment. I completely reworked the 5.0 harness (stripped out a bunch of stuff) so I was really nervous that I might have really screwed something up. It actually fired up on the 2nd try (had to bump the timing back a little bit).
I took all of my harnesses out and am in the process of taping them up. I'll reinstall and make the final push to getting this thing on the road.
Spent last weekend doing a couple of little things, but most importantly got the YJ brake booster mounted up the brake lines fabbed up. I'll bleed them this weekend and hopefully get my engine and body harness loomed and mounted.
Been a super busy month. Really hammered on things.
Got brakes bled and still had no pedal. Opened up the (used) TJ brake booster to find that someone had removed the adjustment screw. New screw in there and I have brakes!
Got the interior finished and tested (for the most part)
Got all of the engine back together, got the power steering hooked up, and wired up the alternator and starter relay.
Girlfriend helped me install the windshield
Took it out to have exhaust put on it. While my exhaust guy had it on a lift I installed the driveshaft.
Later that day I drove it for the first time down the long driveway and on the road a bit. Man, what a feeling.
Still have it, with a long list of stuff to do/fix this winter!
Need to finally find a top/doors for it. Need to chase down some kind of noise in the transmission (main bearing spinning maybe?). While I'm in there I think it's time for a hydraulic clutch.
Nothing (a lot of) money can't fix :D
I guess our only options for a softtop is the Bestop at $1000 right? I'd love to do a half hard top but I feel like I'm too tall for it (the one I had made me feel like my head was against the top)
There is B-D Co, but they are more $$ than bestop.
B-D Co
They are making the old STC tops.
If you really want the half hard top, then maybe you could cut down the seat brackets to lower the seat?
