Changed some of the motor mount bolts. Need to find some 3/4" long 3/8" bolts for the engine block. I can swap them out one at a time later on.
Driver side:
Passenger side:
Technically, I should have painted the engine mount plates, but since I am not painting the engine, I wil live with the Patina.
Where I am NOT taking shortcuts, the important stuff. Since I have to swap out the power steering box for a new one, I am also going to upgrade the steering box mount, front shackle hangers, and add a steering box cross brace. Ordered all these parts from M.O.R.E., just waiting for them to be delivered.
This Jeep might not ever go off road, but the bigger tires kind of dictate these upgrades IMO. And, its tore down this far, might as well do the upgrades now.
Pulling the Pitman arm nut and washer off, 1-5/16" socket needed:
Trusty oiled up pitman arm puller installed:
I would tighten the puller up with the impact, smack the pitman arm with a hammer, repeat. Pitman arm off:
I also pulled the front bumper out of the way. If I have to swap a steering box out, pulling the grill off makes to much sense, it is a PIA to loosen up/reinstall the PS lines with the radiator/grill in the way.
Room to work:
I dropped the shackles down out of the way, removed the bushings from the shackle hangers, for safe keeping:
Removing any bolts from the frame that thread into the "welded inside the frame captured nuts" is always fun. I don't care if the Jeep is 100% rust free, I always respect these bolts. Even without rust, I am pretty sure AMC applied some type of thread lock to these bolts when originally installed.
I don't even try any "magic lube snake oil" anymore. I go right for heat. I use a little MAP gas torch, heat each bolt for about 4 minutes before I even think of putting a wrench on it. Even after it breaks free, if it gets tight again, I reheat. I have the most success this way. Just have a fire extinguisher handy, use common sense. Any old chemicals inside the frame rails can/will catch fire. Also, wear gloves. Your sockets and wrenches will get hot, too.
Started on the easy side, success!!!
When you initially break the super heated bolts loose, it is usually accompanied by little rust dust cloud explosions LOL.
Anyway, hard side done, too. Heat is your friend!!!
Favorite pick, all 5 of these bastards out without damaging the internal frame nuts!!!
