I used 5 cans of that Internal Frame Coating. I taped up every hole and put their spray tube on a coat hangar to pull through with some control. It is very liquid when you spray it and it will drip out of any holes as you can see in the pics. In the last shot, you can see through some of the frame holes. The 5 cans did coat it very well. Hopefully this stuff is good. The outside of the frame was done with their Ceramic 2K Aerospray primer and 2K Aerospray Satin Chassis Black. I did some tests and it withstood all kinds of fluid, including brake fluid and gas, very well. The other rattle can paints bubbled and peeled quickly. Also did some impact and scratch tests. Some pics of the paint test are attached too. All those metal pieces are sitting outside now as a long term test.
