Thinking about spraying this inside my windshield frame.
Flatie46
Russllville
TN
I bought several cans of this Eastwood internal frame coating, considering maybe coating the inside of my windshield frame. Anyone used this stuff? Pro's or cons about doing this? I thought it was either this or pour epoxy paint inside it and roll it around.
I used it on my frame. I don’t see why it would not work inside the windshield. Are you planning to repaint the windshield? That stuff gets everywhere and does not want to come off. I still have it on my wall and on my plastic windows.
Well no, I have a new windshield frame and a good used one I planned on using it on. They will get painted somwtime after. I thought it might be a way to prevent future rust.
Very good idea. I have the windshield frame and the hood left to paint on my current Scrambler project. The inside of the frame is going to get painted first. Thanks for sharing.
I've never used this stuff, bought 4 cans. Gonna do my frame and I can't think of any reason not to use it on the inside of the windshield frame?
I like that plan. Maybe it will help seal up the two halves of the shell and keep water from even getting in in the first place.
I used it on my frame, windshield, and the area between the side panel and skin on the side of the front fenders.
As mentioned, it is very thin (capillary action?) when applied but dries tough.
Mine hasn't been outside yet so I can't comment on the durability.
I used urethane epoxy primer. Tape up the openings, fill and slowly rotate in all directions. Hits all spots and leaks out the seams. Like better than the frame sealer which can cover (bridge over) the seams of the frame. Good epoxy is good protection from water and can also be coated with paint for additional protection.
Is there any concern with the frame coating being used in the defroster ducts (windshield frame)?
I used 5 cans of that Internal Frame Coating. I taped up every hole and put their spray tube on a coat hangar to pull through with some control. It is very liquid when you spray it and it will drip out of any holes as you can see in the pics. In the last shot, you can see through some of the frame holes. The 5 cans did coat it very well. Hopefully this stuff is good. The outside of the frame was done with their Ceramic 2K Aerospray primer and 2K Aerospray Satin Chassis Black. I did some tests and it withstood all kinds of fluid, including brake fluid and gas, very well. The other rattle can paints bubbled and peeled quickly. Also did some impact and scratch tests. Some pics of the paint test are attached too. All those metal pieces are sitting outside now as a long term test.
Frame 1.JPGFrame 2.JPGFrame 3.JPGFrame 4.JPGFrame 5.JPGTest 0.JPGTest 1.JPGTest 2.JPGTest 3.JPG
5 cans? I only used 2. Now I am worried I did ‘t use enough. I guess time will tell.
View attachment 91379View attachment 91380View attachment 91381View attachment 91382View attachment 91383View attachment 91384View attachment 91385View attachment 91386View attachment 91387
Nice, I'm planning to do the exact same thing with my frame. Just did the axles and assorted small parts and it came out very well.
