- Richmond
- TX
External pump, need to figure out how to get feed and return lines installed, and it uses a bolt in flange. For the 20 gallon tank, there is much work needed to get it functional.
There are other fuel sending units that use a similar system.
The ones I really want are those used in planes that have no moving parts and use pressure transducers. But I have not found one with the appropriate ohm range. To widen a search, you can look for mopar compatible units as AMC and Dodge/Plymouth/Chrysler both used the same ohm range.
Another option is to find a quality Mopar sending unit and rebuild it for our application.
Just brainstorming out loud.
