- Biloxi
- MS
Did something to this one today that I have been wanting to do for awhile - removed the plow!!!! Well, the "easy" part of it. Some of these pictures are for my reference, especially the first one.
I had 8 links of chain dangling, 9th link in the slot:
I had to block the plow up to take the chain out, reinstalled with more slack, like 4 links hanging:
Raised the plow up, removed the concrete blocks, set the plow directly on the ground, removed the lifting chain. Undo the two hydraulic lines, quick connect fittings:
Pull the two quick disconnect pins, one on each side:
The two pins hold the black lower sub assembly that holds the big yellow blade to the sub frame assembly that remains bolted to the Jeep's frame:
Simply back away leaving the plow behind:
Plug the pins and keepers back in place for safe keeping:
The Jeep frame mounted lower assembly can be removed by unbolting it from the front frame cross member (similar to a winch mount with the big angle side plates):
And a bolt through each frame side rail back by the motor mount bolts:
Removing the front plate/lift cylinder assembly/"antlers" that hold the plow lights would entail disassembly of the hydraulic system, so not for today. For now, the plow is out of the way and I can easily hook it back up to move it around the yard, if needed.
